20K Miles on factory struts after Prokit and Spoon springs. Worn struts?
  1. 02SilverSiHB
    02SilverSiHB Senior Member
    Jan 3, 2018
    1,890
    1,205
    Pasadena, MD
    2017 FK8
    #1 02SilverSiHB, Jul 9, 2019
    I wish I had made a vid, but I was too tired after uninstalling my spoon springs...so I have a question
    If you press down on a strut (the fronts) it should come back up immediately right...not slowly like a snail?
    Both sides on the front were like that. I had probably run 18k miles with the prokit and 3k miles with the spoon springs. To be clear...I just went back to factory springs this past weekend.
    I didn't see any oil anywhere to make me think it had blown...but I could have sworn struts like that should come right back up when you push down on them.
    IMO, the prokits felt really harsh around this area where I live, Spoon was more comfortable. Both have about the same spring rate, but Spoon was designed slightly different
  2. boosted180sx
    boosted180sx Senior Member
    Mar 27, 2017
    3,203
    2,556
    torrance, ca
    2017 CTR, 2019 370Z Nismo, '16 ILX
    Not necessarily. They aren't suppose to rebound immediately like a spring does.
    Most of the time, the rod wouldn't come back up at all if it is blown and have little to no resistance when pushing down on the rod.
    .grimace and 02SilverSiHB thanked this.
  3. OP
    02SilverSiHB
    Jan 3, 2018
    1,890
    1,205
    Pasadena, MD
    2017 FK8
    okay, awesome, I was a little worried, lol. Good to hear
  4. Gunther
    Gunther Member
    Jul 7, 2019
    48
    dat ol' Virginee
    E46
  5. Type-JZ
    Type-JZ Senior Member
    May 1, 2017
    469
    238
    '13 Lexus GS350, B13 Sentra SE-R, '93 Camry, '07 TSX, '13 Odyssey
    you did lose an inch or so of travel and stiffer, so it would be quicker vs stock. Best is to ride in someone's lowered car to compare. Blown shocks have oil leak(which you said you did not find) or when you press on your car, it would float or like it was riding on springs only. But sometimes w/ stiffer suspension, might be hard to tell. If your handling and ride didn't noticeably suffer, then i say you're fine.
    xABNINx thanked this.
  6. OP
    02SilverSiHB
    Jan 3, 2018
    1,890
    1,205
    Pasadena, MD
    2017 FK8
    Nah sounds like every thing is okay with what was mention by the others above.
    Not sure why I'd ride another person's lowered car lol...I'm on stock suspension
  7. idragmazda
    idragmazda Senior Member
    Apr 21, 2018
    603
    425
    Occupation:
    M&A
    Philadelphia, PA
    Depo
    Current: 2018 Type R, 1977 CB400F; Previously: 2018 Civic Si Sedan, 2006 Civic, 1992 Mazda B2600i
    Are you reverting back to stock springs? My wheels finally arrived after a 6 mo wait and now I’m trying to decide whether to
    (1) Lower with sport line and go 265/35/18
    Or
    (2) stock springs with 265/40/18 or 270/40/18
    Any thoughts on long term use of lowering springs?
  8. jasonjm
    jasonjm Senior Member
    Jul 29, 2018
    640
    292
    Pennsylvania
    Jason
    Type-R
    Stock is best unless you pay up for quality coil overs. Everything in between is more for looks than performance, as you want some adjustability (coilovers and settings). Stock is pretty low (comparatively), and has adjustments and that can get you far depending on the track.
    My only gripe is not being able to use comfort mode suspension but r mode everything else for a bumpy track or back road.
  9. Type-JZ
    May 1, 2017
    469
    238
    O, from the title it sounded like your lowered so I said to compare in someone’s lowered car.
  10. RacingManiac
    RacingManiac Senior Member
    Jul 29, 2018
    431
    226
    Detroit, Michigan
    Jen
    2016 VW GTI, 2018 ABM CTR R-17001
    It also highly depends on how much gas charge there is in the shock to start and what kind of tuning the shock has. The factory adaptive shocks are designed to fail somewhere in the middle of the damping range and for a performance car that is usually pretty stiff. Failsafe meaning there is a mechanical(controlled) valve in the system that is designed to be the main source of damping where there is no current supplied to the shock(which for a removed strut that is the state it will be in). Also for these tri-tubes(yes that is a thing) they don't need a lot of gas charge.
  11. OP
    02SilverSiHB
    Jan 3, 2018
    1,890
    1,205
    Pasadena, MD
    2017 FK8
    maybe go with 255/40 and stay on factory springs...that should fill in the gap a tad and look fine
    Oh, lol, I see
    yeah, I feel the same. I don't want to lose the choice between modes by going with coilovers...guess I'll be on factory springs from now on
  12. RacingManiac
    Jul 29, 2018
    431
    226
    Detroit, Michigan
    Jen
    Also FWIW blown shocks don't always leak, if you have a disc cracked or something it would be fine outside but makes no damping force, if its actually slow in extending it actually probably is making damping force unless you actually lost gas pressure. Which actually would have a leak.
    Adaptive shocks like these actually won't be as bad for lowering because its probably compensating for the lowered ride height actively, the normal cars lowered on conventional shocks will likely run into issue of either under damped so it rides poorly or bottoming/ topping and that might mechanically accelerate wear. Adaptive shocks will see the car being closer to end stop and increase damping to try to stop the movement. The failure mode would be more likely seal related as the shock might be running more pressure than what normally would have vs the standard duty cycle.
  13. SHIFTT_IX_MR
    SHIFTT_IX_MR Senior Member
    Feb 18, 2019
    59
    Naples, FL
    2006 WW EVO 9 MR 548AWHP @ 30psi w/ E85; 2018 CBP Civic Type R #21151 - DD
    AGREED. The stock is very good, but if you want it lower, I wouldn't run anything less than a good quality coilover setup like Zeal, Forture, etc. NO TEIN! Steel + plus welds = crap. Sorry Tein.
    D2's are actually very good for their price. CNC all aluminum, no welds, at least that's how they were on my 350Z at that time.
  14. Hayabusa160
    Hayabusa160 Senior Member
    Jun 19, 2018
    213
    70
    New jersey
    Matthew
    Civic type r
    not all struts will spring right back up. koni dont you literally have to pull them back up.
