2020 Civic Si Reviews Compilation
administrator
Administrator
Admin
CivicX.com
Honda
REBELXSi
Señor Member
Not much different than the previous model years... No surprises here.
MaxPower
NJ, USA
2020 Civic Si sedan ABM, 2017 CR-V EX, formerly 2005 Saab 9-2x, 1986 Prelude Si
Has anyone (in these reviews or elsewhere) published an acceleration test for the 2020? Ideally someone who also tested a prior year 10th gen Si. I still haven't seen anything concrete regarding the impact of the final drive change. I've read some comments along the lines of "it feels a little bit faster" but I'd like to see some actual data, if it exists.
amirza786
A
Northern California
Making the gearing shorter will definitely increase acceleration, but will affect top speed. Many 2020 owners are reporting that at 70 mph their rpms are are nearly at 3000 while 2017-2019 don't see this rpm until around 80 mph. They will also see more power at cruising speeds because of the smaller gearing
rhino
jacob
Weeb land!
2015 sr5 access cab, 98 civic hx ej7, 2003 KLX400s
my 19 sits at 3k rpm in 6th gear at 70mph
Reading The Drive's review they had the same complaint Alex on Autos did. That new final drive helps with passing power but the high speed highway drone is a bit annoying.
Funny enough, the main knock against the updated 2020 Civic Si is the only mechanical change Honda made: That final drive gear ratio. The previous 4.11:1 setup allowed the Civic Si to hum along at 75 mph in sixth gear with the engine turning below 3,000 rpm, while the new 4.35:1 ratio has it droning around 3,500 rpm. That sounds like a small difference until you're subjected to it for a few hours straight. The extra passing power is noticeable, but so is the 2-mpg penalty versus the 2019 model. We're pretty sure Civic Si buyers didn't mind dropping to 5th or 4th gear for a left lane surge anyway.
amirza786
A
Northern California
It should not run at that high RPM till around 80 mph. My 2018 would just hit 3K rpm around 80, the 2019 has the same gearing
rhino
jacob
Weeb land!
its what my 19 sits at its only 4 months old
fyi im really tired today so idk what it said i think it was 3k or close to it who knows
rhino
jacob
Weeb land!
ya mine dosent sit at 3500 that would be annoying but i never seem to really need to downshift into 5th to pass anyone thou 6th gear can pull just takes a second it seems
JT Si
Place
Car
I feel like the difference in RPM is being exaggerated, although I don't mean to downplay the negative effect of an extra 100-200 rpm at cruising speed.
The 17-19 Si sits at ~2,250 RPM at 60 mph. With the 6% ratio change the 2020 will sit at ~2,380 RPM at 60.
This translates to the 17-19 sitting at ~3,000 at 80, and the 2020 sitting at ~3,175 at 80.
Not even a 200 RPM difference, whoever the reviewer was that said it sits at 3,500 RPM at 75 needs to go for an eye appointment..... Or upshift to 6th instead of cruising in 5th.
MaxPower
NJ, USA
Yes, I understand that...this is the impact a final drive change should have on the gearing (better acceleration/penalty at top end, and associated mpg considerations). But I'm wondering about actual impact/numbers. Nobody has published 0-60 for the 2020?
