2020.0 Garmin Navigation Map Update Available
Patriots1959
Jason
Easthampton, MA
2019 Civic Type R
I've never had luck with updating my maps. I get through the first step, download the file into a thumb drive with 128 GB space, and whenever I try to stick it back to the R it doesn't detect the new file and just keeps repeating step 1 detecting it needs an update. I give up lol
Easus Partition Master Free is a great utility for formatting large flash drives as FAT32 when the regular Windows formatting or the diskpart utility will not allow it.
https://www.easeus.com/partition-manager/epm-free.html
Akutober
Anthony
19 CTR CW
Thanks for the thread. I was able to update painlessly, didn't know you had to plug it in the car first.
JohnOCFII
Minnesota, USA
2017 Honda Civic Touring; 2016 Honda Civic EX-T
Just checked Garmin Express and...
I just did the update, and the map loading into the car got to about 90% and then said update failed. Did it? Where can I check the map version in the car? This is what I see now:
Honda Civic 10th gen 2020.0 Garmin Navigation Map Update Available IMG_0147
fiend busa
2018 Civic Type R
Car doesn't detect a 128gb USB from experience. Try something smaller like 16
SilentMonkCTR
Texas
Civic Type-R
So the car has to be on for 30min. Can I start the update and go driving? Or do I have to let the car sit running idle? Or better yet. Can I do it without the engine actually running?
JohnOCFII
Minnesota, USA
It works fine on accessory mode. I think Honda/Garmin recommends against that just in case the process runs too long and you run down your battery.
SilentMonkCTR
Texas
Civic Type-R
That's no problem. I have a battery tender and will just hook that up while it's going. I just don't want to heat soak my brand new Type-R for 30min. Thanks!
remc86007
Ryan
Jacksonville, FL
2018 Civic Type R
You can let it go while you drive; I've done that before.
Also, having your car idle for the 20min it takes isn't going to hurt the car.
Aje7590
Andrew
Philadelphia
2019 Honda Civic Touring
Just updated my ā€˜19 Civic touring.
Does anyone ever notice any actual changes to the maps? I always update, but Iā€™m just curious if anyone has noticed anything
Chee_hu
Sherwin
Elk Grove, California
#611 Rallye Red CTR | 1998 Civic EX | 2007 Honda Fit Sport
It did for me. The one I used was 128gb. It was a user error on my part. I kept turning the car off before downloading the filed to the drive.
JohnOCFII
Minnesota, USA
I ran the update again and it completed successfully. The items on the screen didn't change, so the map version must be somewhere else.
BarracksSi
DC
Trying to get my update to work correctly, but the head unit fails, saying that thereā€™s not enough memory on the device. I checked the detailed settings (no pic yet of that screen) and it says it has around 2.3 GB available ā€” which seems stupidly low (whatā€™s the total capacity? 2.4 GB?).
hereā€™s the error that the system shows:
Honda Civic 10th gen 2020.0 Garmin Navigation Map Update Available 6B708C2F-C74E-402D-8EC6-6D9F44E302EE
Tonysil
Western Mass
I have this same issue, does anyone have a fix for it?
