2019 ex retroquik
  1. crulio
    crulio Member
    Jul 25, 2019
    Louisiana
    Caleb
    2019 Civi ex
    First time doing a retrofit and I’m really unhappy with the outcome. My cutoff looks terrible and I don’t know why. I read that I should get the motoho1ders for this so I did and it still looks terrible. What am I doing wrong? This is the retroquik kit from TRS.
  2. Moisescanoo
    Moisescanoo Member
    Jul 13, 2019
    Moises Cano
    2017 civic coupe EX-T
    I never mess with retrofit products.
  3. arsh88
    arsh88 Senior Member
    Dec 5, 2018
    372
    153
    Minesota
    2018 Honda Civic Hatchback EX
    You should have just dropped some LEDs in the projector lowbeams. There was no need to do anything more than that.
  4. krees
    krees Senior Member
    Sep 17, 2017
    637
    538
    FL
    2018 Civic type r & 2017 Subaru WRX
    If you used the mini h1 projector, the shield is probably not bent/curved correctly. That's why I always get the d2s projectors. I had the first version of the mh1 projectors and I had all kinds of issues though I've never tried the newer ones. After that, I stuck with d2s and never had an issue since. I've done about 4 retrofits total so I'm no expert but I am somewhat knowledgeable. You can probably mess with the sheild or bulb spacing and get it better but that's lots more work.
    Another tip: always test the light output on the car before you seal the cover to the housing.
    crulio thanked this.
  5. OP
    crulio
    crulio Member
    Jul 25, 2019
    Louisiana
    Caleb
    2019 Civi ex
    If my goal was to just change the color, I would’ve.
  6. julianzh
    julianzh Senior Member
    Apr 1, 2016
    381
    138
    Quincy
    2016 Civic EX-t
    It's a defective kit. Exchange it or refund It.
  7. Lucy17
    Lucy17 New Member
    Aug 4, 2019
    Michigan
    Jake
    2017 Civic Hatchback LX
  8. Donuyen18
    Donuyen18 Senior Member
    May 22, 2016
    694
    518
    Garden grove
    Honda s2000
    Seems like this thread devolved into a TRS dump thread. As someone stated above, probably just got a faulty pair or yoi bought their "value" pairs of projectors. They definately have their ups and downs but i would use TRS over most other 3rd party and china brand projectors. That being said, the driverside seems to be suffering from a bilb seating issue
  9. OP
    crulio
    crulio Member
    Jul 25, 2019
    Louisiana
    Caleb
    2019 Civi ex
    After doing a little shimming I was able to get them looking better. Definitely not dumping on TRS. They’ve been great. But the upgraded bulb holders are pretty useless imo. Also these are the Mini H1 7.0, not bargain bin projectors.
  10. Lucy17
    Lucy17 New Member
    Aug 4, 2019
    Michigan
    Jake
    They could use a little bit more to get em perfect but that is a whole lot better
  11. yamin1021
    yamin1021 Senior Member
    Oct 31, 2017
    97
    cn
    2016 civic ex
  12. OP
    crulio
    crulio Member
    Jul 25, 2019
    Louisiana
    Caleb
    2019 Civi ex
    No
  13. yamin1021
    Oct 31, 2017
    97
    cn
    2016 civic ex
    then fine tune your projectors, mini h1 is pretty good compare to drop in led.
  14. OP
    crulio
    crulio Member
    Jul 25, 2019
    Louisiana
    Caleb
    2019 Civi ex
    I mean, for $120 they should’ve worked properly out of the box.
  15. nfsw_andy
    nfsw_andy Member
    Aug 18, 2019
    Andy
    2019 Civic Si, 2006 Acura RSX-S
    How did you install the mounting adapter, if you put it between the shield and lens, you will get shitty results. It has to go between the reflector bowl and shield.
