2019 Civic Sport 6MT - Sedan or Coupe?
  1. Hondaman_MI
    Hondaman_MI Senior Member
    Apr 19, 2018
    547
    337
    17' Civic EX-T
    These are the following differences an Si has, I copied and pasted from another post.
    • engine output increased to 205 HP @ 5,700 RPM (SAE net) and 192 lb-ft torque @ 2,100-5,000 RPM (SAE net)
    • higher maximum boost pressure (20.3 vs. 16.5 PSI)
    • lower compression ratio (10.3:1 vs. 10.6:1)
    • higher-capacity MHI TD025 turbocharger (9-vane vs. 11-vane)
    • helical limited-slip differential
    • larger front brake rotors (12.3" vs. 11.1" vented front and 11.1" vs. 10.2" solid rear)
    • two-mode damper system with normal and firm settings
    • SPORT mode replaces ECON mode - increases suspension damping, reduces power steering assist, increases throttle sensitivity, and raises the activation threshold of the Vehicle Stability Assist system
    • 235/40R18 91W tires vs. 215/50R17 91H
    • 7% stiffer front spring rate
    • 18% stiffer front upper damper mounts
    • 7% stiffer front stabilizer bar rate
    • 32% stiffer rear spring rate
    • Solid vs. fluid-filled front and rear compliance bushings (rear shared with the Type R)
    • High-stiffness rear upper control arms (shared with the Type R)
    • 26% stiffer rear stabilizer bar rate
    • Si-specific seats with thicker side bolsters, non-adjustable headrests, and stitched "Si" logos
    • red interior stitching, gauges, and Display Audio color scheme
    • black headliner and pillar trim vs. gray in EX-T
    • front and rear facias similar to the hatchback
    • center-mounted polygonal exhaust outlet
    • higher-flowing intake system
    • 23% higher-flowing exhaust system
    • aluminum clutch, brake, and accelerator pedals
    • carbon fiber-look interior trim
    • 10% shorter shifter throw
    • leather-wrapped, aluminum shift knob
    • revised shift linkage
    • increased rigidity of shifter bracket mount
    • 450-watt audio system (same as EX-T coupe vs. 180-watt in EX-T sedan)
    • additional items in Driver Information Display including G-force meter, turbo boost gauge with PSI indication, lap timer, throttle percentage, and brake pressure
    • leather-wrapped steering wheel, shift boot, and shift knob
    • premium fuel recommended
    • tire repair kit including sealant and a 12-volt inflator replaces the compact, temporary spare
    • vanity mirrors are non-illuminated vs. illuminated
    • EPA fuel economy ratings of 28/38/32 city/highway/combined vs. 31/42/3
    • optional summer tires
    • stronger rods
    Shelby_10 thanked this.
  2. baillieul
    baillieul Member
    Jan 23, 2018
    Halifax, NS
    David
    2016 Civic LX
    At the end of the day you are obviously a car guy. Get the Si.
  3. ebhaynz
    ebhaynz Senior Member
    Mar 18, 2017
    249
    121
    Lost Wages, Nevada
    Civic Si 2017
    All prices MSRP:
    LX Coupe - CVT Only $20,650
    LX Sedan - Manual $19,450/CVT $20,250
    Sport Coupe/Sedan/Hatch -
    - Coupe Manual/CVT $21,450/$22,250
    - Sedan Manual/CVT $21,150/$21,950
    - Hatch Manual/CVT $22,250/$23,250
    SI Coupe/Sedan - $24,300
    My favorite out of all these is the SI Sedan, which you can prob get around 23K. 2nd favorite is Sport Hatch Manual, prob $21K. 3rd favorite is Sport Sedan Manual, prob 20K. There are so many choices I can't keep track AT ALL.
  4. jtrader
    jtrader Senior Member
    Aug 28, 2018
    146
    90
    OH
    James
    2018 Civic Hatch Sport CVT, 2009 Escape, 2009 Odyssey
    Kinda in the same boat here. Been shopping manual coupes, and the local dealer has a leftover 18 LX coupe 6MT for 18k. But I really do like the 19 sport models. I loved the Honda Sensing when test driving. And the armrests don't have that funky, scratchy fabric. More like fake leather, which is an improvement. Anyway, not having Sensing is almost a deal breaker. If one could get a 6MT Sport Sedan or Coupe for 18-19k it would be hard to turn down. Maybe by the end of this year?
  5. coo1rim
    coo1rim Senior Member
    Feb 14, 2016
    1,252
    354
    Occupation:
    driver
    toronto
    1998 civic, 2006 yaris, 2008 rav4, 2012 carmy, 2017 Civic LX
    BMW most have some serious mark-up to absorb a $9k loss or maybe they're banking on getting you into another lease since you're business owner.
    I'm not a fan of the 1.5T, but $3k difference for the Si is tempting. In Canada, it'd be more like $9k difference (mainly because Canadian LX has android auto, Heated seat and 6MT).
  6. coo1rim
    Feb 14, 2016
    1,252
    354
    Occupation:
    driver
    toronto
    I like the fabric on my 6mt Sedan. after 90k, it still looks like new and no inching. Also, would hate the plastic stuff on a hot day (I suspect the fabric stuff is more expensive then fake leather). Also, US no-longer offers 6MT in LX trim, so you're going to spend noticeably more then $18k to get a 6MT.
    jtrader and cammyfive thanked this.
  7. ebhaynz
    Mar 18, 2017
    249
    121
    Lost Wages, Nevada
    Civic Si 2017
    #37 ebhaynz, Mar 18, 2019
    I think an 18 LX Coupe Manual for 18K would be a good deal but you should be able to get a 19 LX Sedan Manual for about the same price. Still, if you must have the Coupe Manual maybe the 18 is worth it?
