2019 Civic Si Sedan transmission question?
  1. A2typeR
    A2typeR Senior Member
    Oct 14, 2016
    513
    470
    Ann Arbor
    2019 Honda Civic Si sedan (TSP stage 1) 2016 Mazda Miata Club (Brembo BBS pack)
    So,
    Long Story Short I never got my type R, had one pre ordered but ended up getting a 2016 Miata Club.
    So now I ended up leasing a civic Si and completely love it. I was sold on the test drive. I had test drove lots of other cars.
    Anyway, I have a quick question all the forward gears 1-6 engage normally, have driver 2015 STi, Focus ST, GTI, Fiesta ST and Miata Club all manual.
    So when I shift into reverse there is a mechanical clunking and jerking feeling everytime. It feels pretty rough. This is my first Honda manual driving so I’m not sure if it’s normal. After the rough period which last like about a second the car works fine in reverse. I am usually still moving forward when I’m shifting with clutch fully engaged before putting it in reverse and am basically stopped when I start to go in reverse.
    Thanks in Advance,
    A2Si
  2. 360glitch
    360glitch Moderator
    Staff Member Moderator
    3,919
    3,793
    2017 Civic Si Sedan
    While we can of course tell so much from your post, I'd say that what you are experiencing is probably not abnormal and may smooth out over time.
    jakabony thanked this.
  3. caspar21
    caspar21 2018 Civic Si
    Jun 7, 2018
    567
    387
    south central ontario
    2018 Civic Si
    i noticed shifting to reverse is very rough if your moving at all.
    are you still rolling when you shift to "R"ace?
    A2typeR thanked this.
  4. repeet
    repeet Senior Member
    Jun 3, 2017
    620
    580
    Occupation:
    Retired
    Fort Mill, S.C.
    '17 Civic Si Sedan
    You must be fully stopped to enter into reverse smoothly. Syncros can only do so much.
  5. yyalb
    yyalb Member
    Oct 10, 2017
    Michigan
    Albert
    10 gen Civic Si
    I believe our car doesn't have a synchro for reverse, so it's not wise to shift to reverse while moving forward. Normally I would double clutch at neutral before shifting to R.
    I'm also in A2! Glad to meet you some day! Go blue!
    Konos44 thanked this.
  6. VarmintCong
    VarmintCong Senior Member
    Sep 23, 2016
    1,038
    470
    Massachusetts
    2017 6MT Sport hatch
    You need to be fully stopped before going into reverse.
  7. Neps18Si
    Neps18Si Senior Member
    Nov 11, 2018
    446
    305
    Occupation:
    Porsche Parts Sales
    Davie, FL
    P-Low
    2018 Civic Si sedan, 2019 Civic Sport Hatch CVT
    Yes the reverse is a bit of funky gear to get into...you have to adapt a way of getting into it and just dealing with it.
  8. OP
    A2typeR
    Oct 14, 2016
    513
    470
    Ann Arbor
    Yup probably this, noticed it wasn’t there when stopped. Never had any issues with my other cars. But I guess I will try to stop from now on. Old habits die hard...
    repeet thanked this.
  9. OP
    A2typeR
    Oct 14, 2016
    513
    470
    Ann Arbor
    Hmm maybe not lol.
    It’s weird but only a lease so...
    I will try the double clutch method
  10. BenjieB
    BenjieB New Member
    Jun 20, 2018
    CA
    Ben
    18’ Civic Si
    What I do is I shift it into first (holding the cluth) before putting it in to reverse, and it smooths it out :) Shud try it out
  11. amirza786
    amirza786 Senior Member
    Oct 4, 2018
    3,346
    3,238
    Occupation:
    Director of IT
    Northern California
    A
    2006 Camry SE V6, 2013 Toyota Sienna LE, 2010 Lexus IS 350 Sport, 2018 Honda Civic Si (SOLD)
    I am not experiencing the issue with going into reverse as you are, for me it goes in easy as long as I am not moving forward. One suggestion I would make is when you get your first oil change, consider changing out the OEM MT fluid for Amsoil Synchromesh MT fluid. It will make your shifting much smoother and will over all make your transmission smoother as well. It will not get rid of the notchiness (which is done on purpose), but will make it much less irritating. You would need 2 quarts Amsoil Synchromesh ($16 each) and 2 crush washers for the drain plug and overflow plug (.50 cents each)
    Mcclaughry95 and BoostedSiCoupe thanked this.
  12. BoostedSiCoupe
    BoostedSiCoupe Senior Member
    Mar 25, 2018
    1,197
    1,036
    Occupation:
    Driving my Si
    Cesspool
    2019 Civic Si
    the amsoil synchromesh definitely smooths shit out in our trannies.
    the lifespan of it isnt the beat tho. it must be changed every ~15k miles
    amirza786 thanked this.
  13. saiko21
    saiko21 Senior Member
    Feb 16, 2019
    402
    174
    Occupation:
    Trust me I am an Engineer!
    Sacramento
    Sai
    2019 Civic Si Sedan, 2005 Toyota Corolla (Sold)
    you can't shift to reverse without completely stopping. As the reverse gear works with the help of idler gear and also there's a lockout mechanism to prevent wrong shift from 6th to reverse while going forward
  14. tehSteve
    tehSteve GrayBeard McGootch
    Sep 3, 2017
    587
    367
    NJ
    Si
    Was moving 2mph forward at a gas station. Clutched in and threw it in R to reverse next to a gas pump. Heard the most god awful screeching from my synchroes.
    Full stop usually works. Sometimes it does get a little rough when you live on a hill and need to reverse backwards up into your driveway.
  15. BoostedSiCoupe
    Mar 25, 2018
    1,197
    1,036
    Occupation:
    Driving my Si
    Cesspool
    2019 Civic Si
    yeah trying to put her in reverse while moving at any speed causes some nasty ass grinds
