Nitroturtle
- Mike
- Feb 3, 2019
- 3
- 354
- 370
- WV
- 2019 PMM CTR, 2006 S2000, 2010 Element EX AWD
80Hz sounds a lot better than 40Hz. Will the c-pillar speakers work for this?Thanks .. If you were using the Lc2i, I am thinking feeding both Left & right into it, and then taking the output, and with a Resistor network, add the Lc2i output to the Honda Sub output, and feed that through to the new Sub amp.
In an Ideal world , your Mono Sub Map would have more than one mixing input , in which case, no need for the resistive adder, just a resistive attenuator to cut down the Honda sub output a little !!
I'll try to find those threads and see what they were coming up with.. sounds like they were on to a good solution.
