2018 Infotainment System
  1. JESFromASC
    JESFromASC Member
    Jun 8, 2019
    Anderson SC
    2015 Silverado, 2012 Impreza, 2007 Rabbit,
    Just got a 2018 R and was wondering three things about the infotainment system:
    1) Can I run an nice simple old iPod shuffle through a USB input somehow?
    2) Any tips on learning to live with the stock one?
    3) Assuming I use sat-nav on my phone is there simply an aftermarket replacement for it that works and has volume control? Maybe a nice Crutchfield sort of thing?
    Thanks
  2. tinyman392
    tinyman392 Senior Member
    May 21, 2018
    466
    260
    Illinois
    Marcus
    '18 Civic Type R (RR)
    1. I thought it supported iPod playback by default. I could be wrong though.
    2. Drive the car in Comfort mode for day to day driving. Put it into sport of +R when you want to have a little fun. It will change the dynamics of the car and give it a different personality. This obviously only applies if you're daily driving it.
    3. Aftermarket replacement what? It has CarPlay and Android Auto which come with volume control baked it.
  3. Andjoo
    Andjoo Senior Member
    Aug 22, 2018
    245
    179
    Vancouver, BC
    2018 Civic Type R - CW #19431
    If you want minimalist, you could just use a USB drive.
    My old Shuffle charged on a doc, and don't think you could use it while it was charging. So not sure how you could plug it up to your car.
  4. r712
    r712 Senior Member
    Nov 9, 2017
    99
    135
    Jacksonville, FL
    2017 Civic Type R (FK8), Previously: 2015 Civic Si (FB6), 2012 Fit (GE8), 1995 Civic LX (EG8)
    1) Like mentioned above, using a usb drive with mp3 files is the simplest option, but I feel like the ipod shuffle should be viable as well? Assuming it runs in some type of usb mode if plugged in like most mobile devices do.
    2) I actually don't think the stock one is that bad, but I almost exclusively use Android Auto.
    3) I personally wouldn't swap out the entire head-unit because there are a few vehicle settings that are tied to it like rev match, oil life, etc.
  5. OP
    JESFromASC
    JESFromASC Member
    Jun 8, 2019
    Anderson SC
    Thanks for the feedback.
    Yeah, I had read some things about the lack of volume knob blah, blah, blah...
    USB port and an old iPod fired right up and sounds fine.
    Interface even works for pause and skip!
    Volume slide on steering wheel...
    Spent all of 20 minutes paying with it so far and seems like all will be just fine.
    I did check with Crutchfield and they said they have nothing so far and didn't sound like anything in the planning stages.
