2016 EX Rear Wheel Noise
  1. B-Rex
    B-Rex New Member
    Oct 6, 2019
    Brandon
    2016 Honda Civic EX
    I've got a 2016 EX with about 44,000 miles on it. Within the last month, the passenger side rear wheel will make a slight noise only when I'm accelerating from a dead stop. I've taken the wheel off, taken the brakes apart, had two mechanics look at it, and both said there was no suspension/brake issues, but I still can't figure out what would be causing it. Any ideas?
  2. shoegazer
    shoegazer assistant to the assistant manager
    Sep 5, 2018
    462
    213
    Raleigh NC
    2018 Civic LX Coupe 2.0 (CVT)
    I think that your springs/shocks are 'loading up' when accelerating and that's the noise you're hearing. But I don't think it's *normal*. See if you can replicate the noise by pressing down on the area over the wheel and loading and unloading the spring.
    There is some known issue with our cars concerning a leaking shock absorber. But I can't recall if it was front or rear. Maybe yours is beginning to fail.
    Good luck.
  3. Mark11
    Mark11 Senior Member
    Oct 7, 2019
    173
    101
    2019 Vic
    take a video with sound
  4. OP
    B-Rex
    B-Rex New Member
    Oct 6, 2019
    Brandon
    2016 Honda Civic EX
    Alright thank you for that. The weird thing is that you can't hear it from outside of the car. We had it up on a lift this past weekend and looked at everything and didn't see anything leaking or broken seals.
  5. OP
    B-Rex
    B-Rex New Member
    Oct 6, 2019
    Brandon
    2016 Honda Civic EX
    I'll do my best to do this shortly. It's odd because the noise can't be heard from outside the car, only the inside. I'll post a video if I'm able to capture it on my phone.
  6. Mikeybc
    Mikeybc Senior Member
    Apr 15, 2017
    298
    126
    Northern Ontario
    2017 Civic Coupe EX-T, 2015 Nissan Murano
    Something rolling around under your rear seat or trunk ?
  7. latole
    latole Civic Lx 2018 Manual , Civic LX 2016 Manual
    Apr 13, 2017
    1,861
    403
    Vaudreuil,Quebec ,Canada
