2016+ Civic 1.5T Air / Oil Separator Product Development
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
Honda Civic 10th gen 2016+ Civic 1.5T Air / Oil Separator Product Development catchcan.aos1_zpsmsvlq6bb
[/URL]
Honda Civic 10th gen 2016+ Civic 1.5T Air / Oil Separator Product Development catchcan.aos2_zpsynrqvwmq
[/URL]
Honda Civic 10th gen 2016+ Civic 1.5T Air / Oil Separator Product Development catchcan.aos3_zpshypzqfu2
[/URL]
“Oh look, another catch-can.” - This was a phrase that we told ourselves we never wanted to hear. Our team has been toying around with a variety of different ideas/concepts over the past couple of weeks until we finally decided upon a finalized design. :)
Crankcase Ventilation Basics:
Engines with power adders and tunes or subject to aggressive driving styles are susceptible to experiencing higher crankcase pressure. Higher mileage engines are more likely to experience worn piston rings, which excess crankcase pressure can play a negative roll in. Reducing crankcase pressure with positive crankcase ventilation (PCV) is essential in increasing engine longevity. PCV systems utilize vacuum to suck combustion pressure out of an engine's crankcase. This air pressure is then introduced into the intake charge as it reenters the engine. Though the PCV system is a great effort, the reintroduced air contains oil vapors which lead to residue build-up and oil consumption issues. These oil vapors cause fouled spark plugs and harmful detonation, which are both major contributors to power output and engine safety. Detonation, especially in a turbocharged application is a big no-no. Any preventative actions to reduce crankcase pressure is always a plus.
What is an Air / Oil Separator?
The Air / Oil Separator (AOS) is plumbed into the PCV system between the crankcase and vacuum source in an effort to draw pressure from the crankcase. Our AOS is designed to promote centrifugal filtration as this pressure enters the AOS separator canister. Through this process oil vapors and other contaminates are separated from the air. Clean air then continues back into the intake system as the oil vapors are condensed to a liquid-state and drain to the bottom of the can. This process improves engine performance, piston ring sealing and oil consumption issues.
What makes our AOS so different?
Our AOS is the largest PCV can on the market at approximately 305 mL or 10.3 fl oz, thus promoting optimal filtration and airflow. This can makes use of any free room there is in 1.5T's tight engine bay. Custom low-profile fittings were utilized for optimal fitment.
We took a unique approach to our design by making this can modular. Customers can choose purchase our can with or without the optional bottom coolant-fed heating plate. The heating plate keeps the AOS the same temperature as the engine coolant, maximizing the evaporation of any water collecting inside the can. Though the AOS still gets the job done without the heating plate, water vapors will be reduced the hotter the can is.
The top plate, bottom canister and fittings on our AOS swivel 360 degrees, the center canister can be rotated in 90 degree increments and the mounting bracket can swivels 270 degrees to allow a universal fitment for future platforms.
Customers can also choose to purchase an optional drain / petcock kit for effortless draining. For those who don't wish to purchase this, the can can be easily taken apart for cleaning and draining by removing the stainless hardware on the top and bottom of the can.
Our can was modeled after industrial Air / Oil Separators that have been proven to operate with 90%+ efficiency with our tasteful, innovative PRL twist!
Kit Includes:
  • Billet 6061 Aluminum AOS Assembly
  • Anodized Exterior & Interior Finish
  • Viton O-Rings
  • Low-Profile Fittings, Anodized
  • Stainless Hardware
  • Lines/Hoses
  • Stainless Clamps
Stay tuned for more pictures and information as product development continues! :thumbsup:
JDM_DOHC_SiR
Uncle Dave
Chula Vista/ Eastlake
2021 Acura TLX Type-S / 2018 Civic Si Coupe
Really interesting design @PRL Motorsports .... clearly you guys are thinking out of the box here on this one.. nice job :thumbsup:
Kane666
Jason
Pennsylvania
2018 Civic Sport Touring
hopefully we get bracket color and hose color options. oh and hopefully this isnt $180+ like mishi.
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Thanks guys, we will have more data on the kit as we progress!
This will most likely only be offered in black with an offset fitting color. Though it is far too early to determine pricing, it will most definitely be over $180 for the base kit. There's no possible way we could offer a machined air oil separator kit this complex and size for anywhere near that price with hoses, brackets and hardware.
Kane666
Jason
Pennsylvania
on an unrelated topic, any chance to offer FMIC kits with red piping?
MGZ
Bay Area, CA
2017 Si Coupe, Previously 2016 EX-L (50k miles)
@PRL Motorsports I noticed that your upcoming flex fuel kit will mount to the same brackets used for the mishimoto catch can so I've held off on purchasing a catch can. Will this mount to a different location?
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
This will be mounting to a different location! :)
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
