TJHeller
- Jason
- Oct 25, 2019
- 5
- 38
- 26
- Midland Tx
- M4, Boxster, X7, F250, F350, CTR,
First track day with the CTR went great. I installed swift R springs, track brake pads, Motul 600 fluid, and some 18" Bridgestone RE71's. I have quite a bit of endurance racing experience and this car is easy to go fast in. The only problems I had were some tire rub on the front, but I just removed the screw holding the plastic fender and bent the metal tab up. Problem solved. Other than that, no problems. Temps were low 70's and I saw NO overheating issues, although I noticed the gauge move a little bit. I'm going to install some adjustable rear camber arms and toe links to get a little flatter tire contact in corners, and add a heavier rear sway bar. It's impressive for a mostly stock car.
