1st time diy brake pads and rotors
  1. julianzh
    julianzh Senior Member
    Apr 1, 2016
    368
    127
    Quincy
    2016 Civic EX-t
    Hello, this is my first time changing brake pads and rotors and need to buy all the tools I needed. I made a checklist and can someone help me out if I am missing anything. Thanks!
  2. calonzo
    calonzo Senior Member
    Feb 13, 2017
    538
    111
    New Haven, CT
    2016 Honda Civic Touring, 2007 Honda Civic Hybrid
    I assume you have a hydraulic jack, preferably a low-profile one? (And don't forget to put blocks on both sides of the opposite wheel.)
    I am about to do mine for the first time on this vehicle, as well. My previous Honda Civic used a Torx bit to remove the caliper (don't remember the size). I hope this one uses the same size.
    Also, when you remove the caliper, you need to hang it to prevent putting stress on the brake line. I use a regular wire coat hanger and run it through the spring or anything that will hold it.
    julianzh thanked this.
  3. REBELXSi
    REBELXSi SeƱor Member
    Aug 12, 2018
    1,429
    1,176
    S/E PA
    '18 Si Coupe
    Man that sounds expensive af. I guess i take for granted having most of that stuff laying around. Never used brake cleaner, thread locker nor "brake parts lubricant".
    Do all X gen Civics come with the electronic parking brake? Might want to check out how to change the pads out in the rear if you haven't already. I hear it's not as simple as pushing the piston back into the caliper for the rears. I've always done my own brake jobs but at 36k+ miles my pads are still pretty beefy.
    Jay19Si and julianzh thanked this.
  4. OP
    julianzh
    Apr 1, 2016
    368
    127
    Quincy
    2016 Civic EX-t
    I watched couple videos on youtube for the 10th gen brake job. The rear is the one that scares me, if I messed up, that's a hole in my wallet.
  5. OP
    julianzh
    Apr 1, 2016
    368
    127
    Quincy
    2016 Civic EX-t
    No, I do not. Can I use the one that came with the car?
  6. OP
    julianzh
    Apr 1, 2016
    368
    127
    Quincy
    2016 Civic EX-t
    also, anyone know the torque specs for the nuts and bolts?
  7. calonzo
    Feb 13, 2017
    538
    111
    New Haven, CT
    This is an excellent one:
    SpringRubber thanked this.
  8. calonzo
    Feb 13, 2017
    538
    111
    New Haven, CT
    You can. But I feel safer with a hydraulic jack.
  9. liquidfusionv
    liquidfusionv New Member
    Aug 28, 2019
    London
    Timmehhh
    Honda Civic 2018
    I would also like to know
  10. davidgostbo
    davidgostbo Senior Member
    Feb 5, 2016
    451
    180
    Texas
    Honda Civic Ex-t 2016
    #10 davidgostbo, Nov 12, 2019
    Hmm I would buy disks and rotors off rockauto.com save you abit of cash.
    Do you have a 7mm Allen wrench?
  11. fitter_here
    fitter_here Senior Member
    Apr 2, 2016
    359
    131
    Ste-Anne-des-Plaines, Quebec, Canada
    Civic LX 2016 Sedan
    Here are the torques:
    Front flange bolts (on caliper pin): 25lbf-ft
    Rear caliper pin: 18lbf-ft
    Front & Rear brake caliper bracket: 80lbf-ft
    julianzh and liquidfusionv thanked this.
  12. liquidfusionv
    Aug 28, 2019
    London
    Timmehhh
    Honda Civic 2018
    Sorry I don't know what this screw/pin bit is called.
    Is that bit 25lbf-ft or 80lbf-ft ?
  13. fitter_here
    Apr 2, 2016
    359
    131
    Civic LX 2016 Sedan
    Flange bolt: 25lbf-ft
  14. fitter_here
    Apr 2, 2016
    359
    131
    Civic LX 2016 Sedan
    Here's a picture of the front brake.
    Don't let the caliper hangs by the hose, attach it to the suspension spring
  15. OP
    julianzh
    Apr 1, 2016
    368
    127
    Quincy
    2016 Civic EX-t
    Yea, have those tools
