18x8.5+35 with 245/40R18 will it rub.
TheRealWizzy
Wisconsin
2017 Civic Si Coupe / 2004 Pontiac Grand Prix
I'm looking to run 18x8.5+35 with 245/40R18 pilot sport 4s tires lowered on either skunk 2 springs or Ground Control sleeves. Anyone know if I will have any issue with rubbing with this setup.
incutebus
K
FR-S, 21 Mk5 3.0 Supra, Lexus F-Sport
I'm dropped a little over an inch with 18x8.5 et36 and 235 40 18 rsrrs which run like a 245 and I don't rub. I do have issues with ground control though!
Moab23
Moe
Honda Civic si
Ground control?
incutebus
K
Oh ok another question since you’re here. Did you use the stock tire on that rim 18x8.5?
In my previous statement I noted that I was running a tire that runs wider than the standard tire. Imagine running a 245 40 18 stock tire.
Moab23
Moe
Honda Civic si
Yeah sry if it’s a dumb question I’m basically clueless when it come to wheels. The bits and pieces I know are From what I’ve gathered in my research. Will 235/40r18 fit a rim that’s 18x8.5 +35 offset?
TheRealWizzy
TheRealWizzy
Wisconsin
Yes
incutebus
K
An 8.5 generally can run up to 255 and down to about a 215. I personally like having a bit more rubber on my wheels.
CTGT2005
CT
18 Civic Si Coupe
Just lowered my car 1" with pro kit. Also got 18x8.5 38mm offset 245/40r18. Test fitting tonight, will report back.
Honda Civic 10th gen 18x8.5+35 with 245/40R18 will it rub. 20180409_131625
Moab23
Moe
Honda Civic si
I have the same drop less than a week. Did yours take Time to settle?
CTGT2005
CT
18 Civic Si Coupe
Have 10 miles on mine. Hot off the press last night! Also tempted fate with a front sway bar install. 0/5 stars, do not recommend. Handles great though.
This picture says it all...
Honda Civic 10th gen 18x8.5+35 with 245/40R18 will it rub. 20180407_213256
incutebus
K
Eibach springs take some time to settle. About a week out it drops about 1/6", well mine did at least. Not enough to get re aligned if you aligned yours.
Been more of a fan of swift springs because it comes "broken in".
Moab23
Moe
Honda Civic si
I’m actually freaking out because barley noticeable but I’m weird so I do. My driver side seems lower than passengers
incutebus
K
Make sure it's the proper spring rate. Stiffer springs take a different time to break in than softer ones. Make sure the part number is correct, I've had issues running different spring rates at one point and it wasn't pretty.
