18 civic ex, 3k miles and the oil smells like gasoline. HELP!?
arsh88
Wisconsin
2018 Honda Civic Hatchback EX
just got a civic in December after having an accident in my old car. I was beyond excited but I’m only at 3k and the oil life shows 70%. That said it already smells like diesel fuel. Am I doing to have issues when I call the dealer to get it looked at? I’ve heard they really don’t want you doing an early oil change the first time but I do not feel comfortable driving it as is much longer. I’m already debating trading it in
dc2turbo
usa
civic,teg
You can change the oil any time you want. the whole break in oil is nothing
jred721
James
Northern Virginia
'20 Accord Sport
Having your car showing 70% at 3K miles isn't something to worry about, my maintenance minder told me to change my oil just under 6K miles I believe. And also, are you sure your oil smells like fuel? I'm not being a smartass or anything but a lot of people don't realize that motor oil has it's own smell to it too and they confuse it with the smell of gasoline. Tbh the idea of trading in my car would not even cross my mind at this point, it's too premature. You could take it to the dealer and see what they say or even better you could send in your oil for analysis at somewhere like blackstone labs so you can ease your mind and actually see what's in your oil and if there is any fuel in there or not.
parshisa
Texas
Civic X Hatchback LX
Trade it in before too late
arsh88
arsh88
Wisconsin
It definitely smells like fuel and not oil. That thought crossed my mind but i had check the oil like 1000x on my lancer and never had a smell of diesel fuel when i checked. The 70% isn't my concern, i've been told these are supposed to be able to go quite a while before needing oil changes. My concern is I'm only at 3k so I'm not sure if the dealership will be a pain about checking it this early into the oil life. It's just my first brand new car (i usually go slightly used), so the intent was to take care of it, thus i'd rather get it checked out to be safe. i wouldn't be trading it in tomorrow, this is just more or less how long do you keep the car if you know it's going to have issues.
MEESE15T
Bret
muskegon,michigan
2018 Civic HB Sport
Don't panic honda has a fix for this issue.the 1.5 turbo is direct injection and are known to get some fuel in the oil.contact your dealer about service bulletin #18-137
caspar21
2018 Civic Si
south central ontario
2018 Civic Si
deep breath! this type of engine will always have oil smelling like gas.
it is the way di engines work. the recall only messes with warmup times.
it has been discussed to death in these forums that the levels of gas in the oil(except in extreme cases) does not degrade the oil enough to damage the engine.
many users have taken oil samples in for chem testing and found the lubrication ability even with it diluted is within spec and safe.
i am over 40k on 2018 si TSP tuned, (mm oil changes at 10%)without the recall done, and have had no noticeable increase in engine wear.
the car feels as tight and strong as new.
jred721
James
Northern Virginia
'20 Accord Sport
He has the 2.0 engine which isn't direct injected but rather port injected, so the 1.5 stuff doesn't apply.
jred721
James
Northern Virginia
'20 Accord Sport
I hear you. I still think having your oil analyzed by blackstone labs AND taking it into the dealer is a safe bet. That way if the dealer doesn't find anything, you'll have an oil analysis coming your way that will tell you exactly whats in your oil. Also, dont sweat taking it to the dealer, just tell them exactly what is going on and they'll look at it. They pretty much have to anyway if you explicitly tell them somethings wrong.
arsh88
arsh88
Wisconsin
Thanks. I set up an appointment for next tues with them. I'd rather them look for 10 min and tell me it's fine, or use one of my free oil changes to be safe versus ignore it and have issues.
nox
2018 Aegean Blue Metallic Civic EX-T
my oil smells like fuel too and it is distinctive fuel smell 1.5 T 8k miles. I haven’t done recall yet.
