Itachily504
- Itachi
- Feb 16, 2018
- 10
- 181
- 282
- Hot ass Texas
- 2017 Aegean Blue Civic Si sedan
Bought 2 more goodies
Good look guys!!!
I just ordered Ktuner with 15% off bc of this post!!!
I bought my Civic new 2 months ago and everyone keeps saying the Ktuner is night and day over stock so I couldn't resist. Also my understanding is that if something bad happens u can reflash the ECU back to stock for warranty reasons before taking into the dealership.Aw jeez. My SI isn't even 2 weeks old. I figured I'd end up with tuner some day... but now I'm tempted to dive in. Seems like the feedback is Ktuner slightly better than Hondata? What is diff between v 1.2 and v 2.0?
It should be noted that if you have a major failure and you flash your ECU back to stock before bringing it to the dealer , the dealer is going to question why you don't have any drive cycle data or readiness status.I bought my Civic new 2 months ago and everyone keeps saying the Ktuner is night and day over stock so I couldn't resist. Also my understanding is that if something bad happens u can reflash the ECU back to stock for warranty reasons before taking into the dealership.
Also I think the only difference is the V2 comes with a small monitor display to use to adjust or watch data.
The V1.2 u have to connect it to a laptop for that
Will cross that road if that ever happens lol. Always the chance with modifing a car, especially with a tunerIt should be noted that if you have a major failure and you flash your ECU back to stock before bringing it to the dealer , the dealer is going to question why you don't have any drive cycle data or readiness status.
Point is they probably aren't going to honor your warranty if it's engine or tranny related so why even bother flashing it backWill cross that road if that ever happens lol. Always the chance with modifing a car, especially with a tuner
Bc how can they prove I did something to the ECU to cause it? Yes I know they may see that there was no data at the time whatever incident happened but they have to be able to prove I did something to cause thus issue. I worked for Chevy for 7yrs as a tech and numerous times Diesels would come in with issues and a tuner would be hooked up sitting on the dash. Most of the time we could prove the problem was a result from that. BUT there were other times where we could tell there was a possibility that a tuner may have been on a vehicle at some point BUT it wasn't any more (reflashed back to stock parameters and tuner removed from vehicle) and we couldn't prove it, thus parts and labor we're covered under warranty.Point is they probably aren't going to honor your warranty if it's engine or tranny related so why even bother flashing it back
"Two of the drive recorder functions of the engine control unit were extended. First, a function was added that can use the vehicle diagnostic tool to freely generate a conditional expression that will record snapshot data as well as to enable modification of the conditional expression. Several patterns of conditional expressions were prepared in advance so that they could be combined to generate the conditional expressions that assure the capability to record the desired phenomena. Next, the system was configured to allow the snapshot data to be transmitted to a server external to the vehicle. The wireless network functionality of the Display Audio unit is used for transmission to the server, and the snapshot data is transmitted from the engine control unit to the Display Audio unit by divided transmission to enable the large volume of data to be handled for transmission between vehicle units, which are intended to handle small volumes of data. This was also done using simplex transmission in order to limit bus load increase on the transmission line. Measures were taken against data loss, as well, by providing for retransmission of the snapshot data even if the transmission is interrupted due to interruption of the power supply or other such reason."Bc how can they prove I did something to the ECU to cause it? Yes I know they may see that there was no data at the time whatever incident happened but they have to be able to prove I did something to cause thus issue. I worked for Chevy for 7yrs as a tech and numerous times Diesels would come in with issues and a tuner would be hooked up sitting on the dash. Most of the time we could prove the problem was a result from that. BUT there were other times where we could tell there was a possibility that a tuner may have been on a vehicle at some point BUT it wasn't any more (reflashed back to stock parameters and tuner removed from vehicle) and we couldn't prove it, thus parts and labor we're covered under warranty.
Your not talking to a car "rookie"
Dealerships will do a lot of bullshit to try to get out of any warranty issue. Guess what, I'll do a lot of bullshit to get that warranty.
Thanks for your input tho.
Snapshoting and having computers talk, store, and send information via bus is nothing new. Again they might be able to pull stuff up and see "there's things that happened out of parameters here" but they can't at that point say me as a customer caused this from a tuner."Two of the drive recorder functions of the engine control unit were extended. First, a function was added that can use the vehicle diagnostic tool to freely generate a conditional expression that will record snapshot data as well as to enable modification of the conditional expression. Several patterns of conditional expressions were prepared in advance so that they could be combined to generate the conditional expressions that assure the capability to record the desired phenomena. Next, the system was configured to allow the snapshot data to be transmitted to a server external to the vehicle. The wireless network functionality of the Display Audio unit is used for transmission to the server, and the snapshot data is transmitted from the engine control unit to the Display Audio unit by divided transmission to enable the large volume of data to be handled for transmission between vehicle units, which are intended to handle small volumes of data. This was also done using simplex transmission in order to limit bus load increase on the transmission line. Measures were taken against data loss, as well, by providing for retransmission of the snapshot data even if the transmission is interrupted due to interruption of the power supply or other such reason."
Just so you're aware of what Honda is doing now.
