10th Gen Civic Light Bulb Size Guide
  1. OP
    TypeRLEDs
    TypeRLEDs #1 Source for 10thgen LEDs
    CivicX Basic Sponsor
    Mar 13, 2018
    520
    339
    Houston TX
    2017 Honda Civic Type R
    28685493_1857622290928920_8000531647239815168_o-L.jpg IMG_20180306_224758-L.jpg
    Prelude2CivicX and MacKharoni thanked this.
  2. Axatax
    Axatax Senior Member
    Apr 23, 2017
    704
    404
    Occupation:
    Underwear model for JCPenny
    In Malkuth, surrounded by evil, low on gas.
    2K Civic DX Coupe B18C5 (swap), 2017 Civic LX Coupe 6MT
    The LED between the map lights is surface-mounted onto a circuit board. You'd have to de-solder it to replace it.
    TypeRLEDs thanked this.
  3. a c i d.f l y
    a c i d.f l y Senior Member
    Sep 25, 2017
    681
    320
    Austin
    #18 a c i d.f l y, Apr 4, 2018
    My vote for a sticky thread, but should probably be moved/copied to the exterior forum.
    Thanks for posting this, btw.
  4. OP
    TypeRLEDs
    Mar 13, 2018
    520
    339
    Houston TX
    Thanks! Glad the guide is useful.
    Updated. Indicated Front and Rear Turn signals.
  5. a c i d.f l y
    Sep 25, 2017
    681
    320
    Austin
    Is there any way to replace the subtle light in the storage area under the head unit without ripping things apart? Would like to replace that with a green instead of the blue...
  6. chestypuller
    chestypuller Senior Member
    May 3, 2018
    283
    81
    alaska
    Skip
    None
    depending on what bulb it is, they make silicon colored covers to tint them check into that maybe easy
  7. CivicChina
    CivicChina Senior Member
    Jul 14, 2016
    1,121
    616
    Occupation:
    Designer
    Xiamen, China
    Civic 1.5t 6MT Cosmic Blue
    As far as I know, the low beams are H11, not H11B
  8. M1KL83
    M1KL83 Senior Member
    Mar 31, 2018
    152
    34
    Ontario, Canada
    Michael
    2018 Civic Hatchback LX 6MT, 2002 Honda Accord SE 5MT
    Parts Source says the factory side marker bulbs are 2821's and at 3 amps..
    194's are 3.8 amps.
    What is right?
  9. Kirinya
    Kirinya New Member
    May 20, 2018
    Austin
    Kevin
    2018 Civic Hatchback EX
    I thought it was a dim white light to start with?
    I would also like to know this, want to replace with a brighter light to see the storage area.
  10. bri
    bri Senior Member
    May 22, 2018
    319
    139
    OC, CA
    2018 Civic Type R, 2010 G37S
    I believe the reverse backup lights in sedan are 921, same as nearly every other car. I just replaced mine with LED.
  11. OP
    TypeRLEDs
    Mar 13, 2018
    520
    339
    Houston TX
    Yes. Correct. Same as T10.
  12. bri
    bri Senior Member
    May 22, 2018
    319
    139
    OC, CA
    The socket is the same, but in incandescent 921 are higher wattage and burn brighter. Accordingly, 921 labeled LEDs typically are much brighter (even though the wattage is in a different range than incandescent) using larger number of higher output LED chips than T10/194 labeled LEDs. T10/194 labeled LEDs are going to be really dim in a reverse socket.
    Handy2Do thanked this.
  13. danny185
    danny185 Senior Member
    Mar 3, 2018
    158
    Puerto Rico
    Danny
    Honda Civic SI 2017 Sedan
    Hey guys I got the brake light on led but what are the ones that illuminate the whole red light on the tail lights? What bulb size?
  14. Accordlayingkit
    Accordlayingkit Senior Member
    Jul 21, 2018
    106
    54
    Virginia
    2017 Honda Civic Hatchback EX
    #29 Accordlayingkit, Jul 26, 2018
    Anyone got a link to order the visor bulbs that have been confirmed to fit and work? (T5 bulbs)
    Thanks!
    Edit: you guys think these will work in the visors?
    iJDMTOY 4pcs Extremely Bright 9-SMD 29mm 6614 LED Replacement Bulbs For Car SUV Truck Sunvisor Flips Vanity Mirror Lights, Xenon White https://www.amazon.com/dp/B018J69J6W/ref=cm_sw_r_other_apa_.Y-wBb95E38B4
    Or these
    LEDpartsNow 5mm LED Light Bulbs for Vanity Mirror Sun Visors, T5, 70, 74 Basic Miniature Bulb (2 Pieces), WHITE https://www.amazon.com/dp/B075L3XPGG/ref=cm_sw_r_other_apa_t0-wBb1F8AB34
    I'm guessing it would be the 2nd ones since those visor bulbs are wedge style
  15. Accordlayingkit
    Jul 21, 2018
    106
    54
    Virginia
    #30 Accordlayingkit, Jul 28, 2018
    I forgot to get rear amber LEDs for my turn signals so I plan to order. I'm guessing this below is to cure any hyper flash?
    *Note if installing LED turn signals for front and back; you'll require a load resistor for either both or one.
    Anyways ...what are load resistors and where do I get them from?
    Thanks!
    Edit: figured it out lol
    https://www.civicx.com/threads/turn-signal-led-bulbs.4977/
