10th Gen Civic Garage DIY: Taillight Removal. Turn Signal, Brake, Reverse.
  1. TypeRLEDs
    TypeRLEDs #1 Source for 10thgen LEDs
    CivicX Basic Sponsor
    Mar 13, 2018
    459
    322
    Houston TX
    Nhan
    2017 Honda Civic Type R
    #1 TypeRLEDs, Apr 30, 2018
    Hello Everyone. Thank you for joining us.
    Here is a DIY, Do it yourself ,tail light removal for the 10th gen Civics. The steps are similar if not identical for all 10th gens.
    Tools needed:
    8mm wrench or Phillips head screwdriver.
    Recommend using 8mm
    The bolt is prone to stripping from the Philips head. (Thanks @CobraCommand)
    Masking tape and microfiber towel.
    Optional panel trim puller
    Difficulty Easy (2/5 stars)
    I AM NOT RESPONSIBLE FOR ANY DAMAGES, FIRES, CUTS, BRUISES, STOMACH ACHES TO YOU AND OR YOUR VEHICLE.
    Let's have some fun:)
    Step 1. Mask off the edges in between the bumper and the tail light to prevent scratches.
    Step 2: Unscrew 2x 8mm bolts using a 8mm socket wrench. Check out the blue circles in the photo. Tail light is held in position by these 2 bolts and 2 buttons. You'll see where as we progress.
    Step 3: Gently pull the tailight away from the car from the rear. A gap will open. Insert your fingers (green arrows) and move towards the front of the vehicle (blue arrows). It will get tight and you'll soon run out of space. Skip to the next photo.
    Step 3 continue: look at this photo. I have circled the buttons that hold the tailight to the vehicle. Pull out and away from the vehicle keeping the tailight parallel to the vehicle. The tail light will pop out.
    That's it! Tail light has been removed.
    To pop the tail light back into place: line up the white buttons. And push the tail light until the buttons pop back into place. With enough pressure you'll feel and hear it kind of snap into place.
    Continue for Turn Signal, Brake and Reverse replacement
    Step 4: locate your desired bulb.
    Reverse: Light Blue
    Turn Signal: Orange
    Brake: Red
    Twist counter clock wise to remove. Righty Tight, Lefty Loosey.
    Step 5: Replace with desired LED or stock replacement.
    Step 6: re insert bulbs/LEDs and twist Right to tighten.
    Step 7: Reep the rewards.
    End Scene.
    WhatThePuck, 86salmon, yhkwok and 5 others thanked this.
  2. tuxmonkey
    tuxmonkey R-00330
    Oct 3, 2016
    600
    434
    Houston, TX
    '17 Civic Type R #330, '17 Jeep GC Overland
    Great tutorial. Detailed and straight to the point. Looking forward to getting these LEDs.
    TypeRLEDs thanked this.
  3. CobraCommand
    CobraCommand Senior Member
    Jun 28, 2017
    442
    411
    NS, Canada
    2019 Canadian Civic LX Hatchback, formerly 2017 Canadian Civic LX Sedan
    I replaced my lights and I would only recommend using the 8mm socket. The screws are such soft metal I have one strip trying to get it out. - no problem with the socket though.
  4. OP
    TypeRLEDs
    Mar 13, 2018
    459
    322
    Houston TX
    Nhan
    Thanks! I will add that!
  5. OP
    TypeRLEDs
    Mar 13, 2018
    459
    322
    Houston TX
    Nhan
    Bump for those who are asking or looking!
  6. OP
    TypeRLEDs
    Mar 13, 2018
    459
    322
    Houston TX
    Nhan
    Again for those who need this .
  7. NoHonor937
    NoHonor937 Senior Member
    Jan 4, 2019
    612
    244
    dayton, ohio
    2017 Lunar silver coupe 1.5T
    Yes I have a question or two: are the brake lights separate from the illumination lights that come on by default when headlights come on? Also I have a coupe. Are the bulb sizes the same for them?
  8. OP
    TypeRLEDs
    Mar 13, 2018
    459
    322
    Houston TX
    Nhan
    We've been getting messages to locate our guide. :)
