NorthernEX-T
- Feb 2, 2016
- 70
- 3,570
- 3,601
- Canada, EH.
- 17 Type R
- Vehicle Showcase
Alright so here goes. I took my sample yesterday and put in some more fresh stuff. Using an AMSOIL filter this time so I am expecting even better results.
Facts on how I've ran this oil:
- AMSOIL 0W20 Signature Series & Mobil 1 extended performance oil filter.
- No change in dipstick level whatsoever. Honest as anything. Stayed at the full mark the whole time.
- Temperatures ranged from -23C - +7 C & Car was outside entire time (no warm garages, only when I change my oil)
- Car is running 20.5 psi tune from Hondata.
- Oil was used for 7000kms (4400mi) (200hrs)
- Oil life went down to 60%, which I was impressed with, I feel like it goes down faster than that normally because when I change it at 10,000 it's usually at 20-30%.
- Oil was put to the test for sure,, cold weather, cold starts, no block heater, 20.5 psi vs 15 psi stock, I saw a few boost peeks that turned the engine up to 6200rpm, she really takes off then!
I sent out the sample today and will post report back when it comes in.
Threw this in the garbage..
What it should look like under the oil cap ^
Beautiful
Used stuff & filled sample ^
Little tip, tuck a rag in like this and it helps keep it clean when you spil oil the rag will soak it up instead of disappearing into the black abyss around the fill hole.
Tasty stuff.. ^
Beautiful
Tasty stuff.. ^
