Molatte
Hello.
So after about 1000 miles or so and around a month of owning my Touring, I got a little surprise as I was about to commute to work yesterday:
And that surprise was.. my touring wouldn't start up. And I was very surprised because...well...its only been 1000 or so miles and there weren't any prior indications that the battery was about to die.
So I called road assistance and immediately booked to have my battery replaced that same day. I went to the dealer and waited about 2 hours and got the battery completely replaced. I should note that, after I got the car jump-started, several errors appeared in my infotainment system such as:
1) 12 Volt Charging Problem
2) ACC Problem
3) Brake System Problem
4) CMBS
5) Tire Pressure System Problem
And when I got the battery replaced (through warranty ofc) these problems still appeared in my infotainment system. To which I just ignored and eventually they disappeared by themselves.
Today, I decided to go to the park and everything was still fine. It was on my way back home that these problems re-occured on the infotainment system.
My question is...do I really need to go back to the dealer and have this sorted out? Or is this just a malfunction that appears every now and then?
Has anyone had this problem before (the errors appearing on the infotainment system)?
Thank you.
2) ACC Problem
4) CMBS
Thank you.
