sesty
- Oct 16, 2017
- 12
- 92
- 35
- Jersey Shore, NJ USA
- Civic Si Sedan
Started car up and was getting a CEL and pretty much all systems failure even though the car drove fine. Code was P0304 - misfire cylinder 4. You could hear a slight misfire on idle if you listened at the exhaust. Pulled the neg terminal and the lights came back after a short drive... checked battery voltage which some people have noted could cause the all system faults...which was ~12.4v...
57k miles dealer is replacing 2 faulty injectors under warranty. I always used Premium... most often from WaWa...and usually run a can of seafoam every 8-10k miles.
