Alex_hockey69
- Alex
- Apr 30, 2019
- 11
- 89
- 11
- Montreal
- 2017 civic si
When changing Manual Transmission Fluid what tool and size is this ??
Both plugs use 3/8 inch square. The fill plug is deep,so the long extension is needed. The breaker bar just gives you longer handle for leverage. If you don't have breaker bar, use the 3/8 socket.When changing Manual Transmission Fluid what tool and size is this ??
Do we need to remove anything to get to the fill plug or can the extension do the job without removing anything?Just need a 3/8 extention and either a breaker bar or a ratchet and a pipe. It's very easy. Make sure you open the fill plug first!
I don't think so but I was running a CAI so I had plenty of room. Should be able to get to it though... With a long enough extension.Do we need to remove anything to get to the fill plug or can the extension do the job without removing anything?
Ok I was asking because I had a look and can’t see it so I assumed the air box had to come outI don't think so but I was running a CAI so I had plenty of room. Should be able to get to it though... With a long enough extension.
Air box doesn’t need to come out as long you have a long enough extension bar. I did my fluid last monthOk I was asking because I had a look and can’t see it so I assumed the air box had to come out
Ok thanks... I’ll have another look to see if I can locate itAir box doesn’t need to come out as long you have a long enough extension bar. I did my fluid last month
Ok thanks!Airbox doesn't need to come out but you will need a funnel that can clear the airbox, or even easier, some tubing that you can poke into the fill hole...
I had another look and I do think that I will need to remove my airbox as I clearly do not see the filler plug.Air box doesn’t need to come out as long you have a long enough extension bar. I did my fluid last month
