Warranty Voided from "Over Rev"
Dre0415
Dre0415
Dre
Michigan
2019 Civic Si
Also one think I forgot to mention is before I picked up the car from page they called and mentioned that they couldnt get 3rd gear to go in. And before bringing it to them I never had any trouble getting the car into 3rd. Which kinda leads me to belive the page dealership couldve miss shifted it.
amirza786
A
Northern California
You can see the mechanic cold start revving in this video if your intrested.
Also iv never miss shifted and if I ever did it definitly wouldnt have done $7000 worth of damage.
You can also see the mechanic swearing at some customer in the parking lot with the windows up so the person cant hear him which is also intresting.
The tech did rev it a bit at cold start, but I don't think that was enough to bend a rod. The rod is already bent at this point from the sound of your engine. He mentioned about flooring it and the RPM's only going to a certain point, which does happen when you have TSP's stage 1 tune which has launch control. Are you tuned at all? Also, what dashcam are you using?
Dre0415
Dre0415
Dre
Michigan
2019 Civic Si
When you cold start a honda i believe it automatically limits rpm to like 4k plus misfire may be preventing to rev all the way.
car wasn't tuned.
Dre0415
Dre0415
Dre
Michigan
2019 Civic Si
Here is my dashcam: https://www.amazon.com/gp/product/B07DF8MQX1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Dre0415
Dre0415
Dre
Michigan
2019 Civic Si
The dealership hasnt said anything about a bent rod to us just that it had a bent valve.
Dre0415
Dre0415
Dre
Michigan
2019 Civic Si
If anyone knows any other possible causes for bent valves let me know
LightX
Andrew
2018 Civic Hatchback Sport
I redline in first gear at 6500rpm and after that, my motor made a rattling noise which increases as engine rev up. After two months of daily, the rod and piston finally gave up blowing a hole. Upon opening up the motor, intake valve was hit and piston shattered where the intake valve hit. The piston ring could clearly be seen from the impact with a big chunk of piston flying around. Surprised it lasted two months like that.
L15BA motor btw.
Dre0415
Dre0415
Dre
Michigan
2019 Civic Si
L15BA motor btw.
Redlining in 1st gear surely shouldn’t cause any damage. The rev limiter is there to prevent damage like this from happening. Unless your talking a miss shift where the rev limiter doesn't help then I'm not sure how that could’ve occurred.
Oddwayne
Nj
19’ Si coupe & 99 ej6
Just a heads up, the car stores all over rev situations. So for warranty work the regional tech will check the computer to see. If it pops up than they know at someone point happened.
LightX
Andrew
Well, it happened. It’s more like the term “the ball tell no lies” when scoring points. I’m not sure how long the debris been there from the piston, but the valve was definitely bent from rev limiter in first gear which I think caused the crack and ultimately shattered when it blew a hole. I was throwing knock control over .90 just an hour of its final life and throwing bluesmoke just the day before.
Honda Civic 10th gen Warranty Voided from "Over Rev" 84877650-755C-40DE-9F37-04341A9D16AD
Honda Civic 10th gen Warranty Voided from "Over Rev" 929C4074-39C2-4437-9D8D-75E5F6C7FADC
LBP
This doesn't look like something that pegging it at 6500rpm in first would cause unless the engine had a defect. Did you moneyshift? That is, downshift into too low of a gear at speed?
Dre0415
Dre0415
Dre
Michigan
2019 Civic Si
Yeah iv heard but nobody from the dealership has mentioned anything about getting a code they just suspect its a miss shift so therefore they're denying my warranty claim?
stevessvt
Lake Worth
2020 Modern Steel Metallic Civic Si
Obviously, and maybe you have, but you need to open a case with Honda corporate, like yesterday.
Dre0415
Dre0415
Dre
Michigan
2019 Civic Si
Already have they didn't help at all. Just said to argue it with the dealership.
charleswrivers
Charles
Kingsland, GA
Review your warranty information. If you aren’t satisfied with corporate, you’re on step 3.
STEP 3
If you disagree with the decision reached by the staff of Honda Automobile Customer Service, you may request to have your case reviewed in an independent forum run by the National Center for Dispute Settlement (NCDS).You may file a claim at any time by calling NCDS toll-free at 877-545-0055.
You may also write to: National Center for Dispute Settlement
P.O. Box 1108
Mt. Clemens, MI 48046
The purpose of NCDS is to
resolve disputes between vehicle manufacturers and their customers. NCDS’s decision makers are impartial third parties who will listen to both the customer and the manufacturer and decide what can be done to resolve the disagreement.
NCDS’s decision is not binding on you unless you agree to accept it.
If you accept the decision, Honda will abide by it. Generally, disputes submitted to NCDS are resolved within 40 days (47 days if you have not first contacted Honda about your complaint).
Honda offers you the opportunity to mediate and arbitrate a disagreement through NCDS because we want you to feel that you have been treated fairly.
Eligibility is limited by your vehicle’s age, mileage, and other factors. In order to file a claim, you need to provide your name and address, the Vehicle Identification Number (VIN) of your vehicle, and a brief statement outlining the disagreement. Initially, NCDS may try to resolve the disagreement through mediation. If this is not successful, your complaint will be reviewed by an impartial arbitrator.You may present the facts of your case to the arbitrator at an informal meeting.
Customer Satisfaction
We encourage you to use this program before, or instead of, going to court. It is informal, free of charge to you, and generally resolves problems much faster than the court system. Lawyers are usually not involved in the resolution of claims through NCDS, although you may obtain one at your own expense if you choose.
If you want to go to court, Honda does not require you to first file a claim with NCDS. Please note that laws in some states may require that you file a claim with NCDS before you can proceed to a state-operated dispute resolution process or the court system. If you do not accept the decision of NCDS, you can still go
to court.
Sucks... with the world effectively shutdown but you aren’t done. I would tell corporate you’re intending to escalate.
