Best touchless air/blow dryers?
MuffinMcFluffin
Brandon
Elk Grove, CA
I'm planning on getting a ceramic coating for my car. Just ordered a pressure washer (still need to find a good soap to use), and would like to go the touchless drying route as well.
Anyone have any good recommendations? Thanks if so!
jayy_swish
Jay
I use Mr. Pink from chemical guys, a gallon runs about $30. Amazing stuff in a foam cannon, foams well! They also sell a different variety/power of air blowers
MuffinMcFluffin
MuffinMcFluffin
Brandon
Elk Grove, CA
How many washes does a gallon last you?
GoldClass
Singapore
Civic Hatchback
Been using Bosch wireless dryer for over a year. It is mobile and I can use anywhere.
Bosch GBL 18V-120 18V Cordless Mobile Blower Light Weight
Honda Civic 10th gen Best touchless air/blow dryers? 133F0719-95BF-4838-8D85-F7E7B12C0747
biosses
Japan
I use a air blower from amazon.com
blitz
Virginia
2019 Civic Type R
I use an auto air dryer (“air cannon”) from Adam’s Polishes. I have had it for about four months, and I am impressed with how it has performed.
Here are a few features that I like about it:
1. Variable speed
2. Hose interlocking mechanism (twist lock)
3. Heated air
4. Premium caster wheels that can be locked, and allow the blower to move in any direction
5. Compact size
6. Long hose they constricts (shrinks) when no air is flowing. It allows for easy storage
7. Rubber hose tips to prevent scratching
Here are some pics of mine:
Honda Civic 10th gen Best touchless air/blow dryers? hRVs56t
Honda Civic 10th gen Best touchless air/blow dryers? V0Jssez
Honda Civic 10th gen Best touchless air/blow dryers? pZoHCwu
Honda Civic 10th gen Best touchless air/blow dryers? QSyEIZO
I purchased mine through Amazon. If you choose this route, then select the delivery option where Amazon packages it in a non-descript box because otherwise it will be delivered in the manufacturer’s box that can be eye candy for thieves.
Thatguyraw
I don’t own a civic
Raw
Long Beach, Ca
2013 Toyota Tundra
Fit2Hatch
Victor
Waipahu
'18 Hatchback Sport
Both Civic and Corvette were done by myself using:-
Optimum Tire and Protection Coating on Tires, exterior trims and wheel wells
Kamikaze ceramic products on body and wheels.
Equipment and chemical:-
Kranzle 1322 pressure pump.
Chemical Guys Snow Foam Auto wash-2oz each in MTM Foam Canon and contact wash bucket.
Brake Buster 1:5 ratio, using IK Foamer on wheels/tires.
Master Blaster blow dryer.
Two hours process for Corvette, slightly longer for Civic, other than contact wash, absolutely no touch and walk away after blow dry.
But..by the way, there is no best, that is only my process and everyone has their own unique style.
So...good luck and hope you enjoy the process on car maintenance.
ApexEight
Anthony
Atlanta, GA, USA
2019 Honda Civic Type R
I've had my eye on this for a while and think I may pull the trigger. After rinsing off the car, I like to take a regular garden hose with nothing on the end and run sheets of water on the car. When done correctly on clean paint, it'll carry a lot of the water drops on the paint along with it. A blower like this would be a great next step to dry off whatever is left and also for clearing out crevices. Spot dry with a nice microfiber and I think that's a solid, safe drying process that wouldn't break the bank.
biosses
Japan
Do it. i checked the price today, i bought it for $42. It's about $25 now. So it's a steal.
kimtyson
Kim
York, Pa
2020 Blue Civic Si Coupe
Look for CFM (cubic feet per minute) specs. There are several cheap (less than $100) blowers out there that do a better job then the boutique name brands. I got a $50 Toro blower at Home Depot. Works great.
Another tip is to use Formula 4 spray to prevent water spots and add shine. Check out the Youtube video on their site. https://superiorproducts.com/product/formula-4-spray-wax/
