macrossranma
- macross
- Aug 14, 2017
- 12
- 113
- 27
- Canada
- Civic SI
what are the currently available stainless steel brake lines for Si?
Our cars are so new. Can you guys really tell a difference in pedal feel after installing SS lines? Iām assuming you didnāt have air in the system prior to install.
Definitely this. Braking response is immediate.Quite a lot of different. It is not so spongy and it gives a liner braking effect. Overall, shorter braking distance and you are in better control than OEM rubber hose.
If it's really that noticeable of a difference, Honda did a really bad job with their rubber hoses. I too feel that the stock pedal feel is a tad spongy and would like it to be more firm but I just attributed that to the sliding calipers. I thought that the only way to correct this would be to upgrade to a front BBK that uses a fixed caliper. But for only $100 and some time I'll give the SS lines a shot.Quite a lot of different. It is not so spongy and it gives a liner braking effect. Overall, shorter braking distance and you are in better control than OEM rubber hose.
Thanks for your feedback. If the lines do noticeably have a firmer feel, even if just slightly, thats a positive. I wouldnāt expect lines to have any appreciable effect on stopping distance. Anyone with common sense will tell you tires then pads are the main factors which you experienced.In my case, Post brake line change, brake pedal feel is slightly firmer but did not significantly shorten braking distance.
Stainless line is a nice first step.
I wouldn't sell them if I didn't confirm fitment on one of our own cars. in this case on all 3 of our SI's@pinhead66 @Si2020
can anyone confirm the part number for the Goodridge SS brake line on the Si sedan?
I looked up the form i see Humza from unity got the 20040 and am looking for further part number confirmation for people that installed them.
Thank you!
