- JW
- Jul 8, 2017
- 1
- 202
- 98
- Somewhere
- 00 Orion Nebula
- Banned
- #31
The 2017-2019 US CTR does not have an oil temperature sensor. Europe does.
My bad, I thought the US versions did as well
is NOT a valid technical conclusion and your statements about Android Operating Systems compatibility is highly flawed. ( FYI: I am an Android software developer)...so the simplest answer [Occam's Razor] as to why LogR is not compatible with the 2017 - 2019 FK8's is that Honda upgraded Android to >=5.0.
KISS: https://developer.android.com/training/basics/supporting-devices/platforms
I'm not going to argue over making a simple generalization to KISS, but since the lack of a sensor or two is not a logical reason to make a metrics app incompatible (it simply wouldn't show something like Oil Temp), it would seem a simpler and more logical reason would be the tablet's firmware has changed, resulting with an incompatibility to run on the current firmware version.
- A more logical challenge to what I posit would be that if it is really just a firmware versioning issue, then it's a simple process of updating the tablet's firmware via HDS and the DST-i.
This is assuming they kept the tablet's hardware the same internally, which they did not, and is why I'm positing it appears more logical the firmware has been changed since it's not the same tablet
('17-'18: 39710-TBA-305 || '19: 39710-TBF-A71)
