My Honda dealer did it...my buddy is a tech. Its definitely a job that should be done on a lift. You need to drop the subframe to pull the trannyNice. Did you install or did you take it to a shop? How much room was there to change out the clutch? I'll have to get a stronger one when I get PRLs turbo.
I'm not looking forward to the cost/downtime of reinforcing the block lol
Best of luck with your new setup!
anti roll bars? and what would you change it for?Uggh figured. Might as well change out the anti roll bars while I'm at it lol.
He’s talking about the sway barsanti roll bars? and what would you change it for?
Hopefully 4pistons after ktuner works their magic.He’s talking about the sway bars
@18RRtypeR looking good man, what upgraded fuel system are you going to be running?
Same thing lol.He’s talking about the sway bars
Got it sounds like something to keep in mind. As far as super street applications go is there any reason for a non tracked CTR to have this changed?He’s talking about the sway bars
Some people want something stiffer...personal preference like all mods!!!Got it sounds like something to keep in mind. As far as super street applications go is there any reason for a non tracked CTR to have this changed?
