Checking 2017 CVT Transmission Fluid Level
sapitsjohn
2017 Civic Hatch LX
Hi all!
First time posting on here and I couldn't really find an answer to my question before this.
Would I be able to check my CVT transmission fluid level with the check bolt anytime? Or does it have to be only when I'm doing a fluid change?
Also, when the fluid is coming out of the check bolt, should it be dripping a drop at a time consistently or have a small stream drain out?
2017 Hatch LX.
Thanks!
sapitsjohn
2017 Civic Hatch LX
From the service manual
If it's flowing you added too much.
Thanks for that! From the looks of that screen shot, is it safe to say I can follow those steps anytime? Or only when I'm draining and adding new fluid?
sLing
2019 Type R
I don't see why you can't. I would add a bit more fluid between checks just to be safe. And just allow the excess fluid to drain until it's a gradual drip.
