I live around NYC/NJ area and have use A/S M+S tires (Bridgestone Potenza, Michelin Pilot Exalto) exclusively on my Prelude for 20 years thru moderate snow storms and light ice storms without problems. I think if your ride is FWD and live in a metro area in NYC or south of, then a good set of A/S M+S should be good enough. With a performance car, it's the low ground clearance that gets you stuck. The only time I got stuck in my Prelude was when I venture out during a snow storm on an incline with about 3 or 4 inches (or maybe more) of snow covering before the first plow truck had a chance to plow and lay down a coating of salt. Good thing I carry a compact shovel and was able to free the Lude back to safety.Using Pirelli Sottozero 3, expensive, but worth it to me. Read the threads, A/S tires are not winter tires.
I don't see the point of doing the wet tests on a track at track speeds.Tires are one of the things you actually get what you paid for. Don't buy them.
I'd imagine nankangs are at the same level as accelera tires.
Speed aside, they're also terrible in wet braking too. Up to you though, it's your car.I don't see the point of doing the wet tests on a track at track speeds.
1. I don't go much over the speed limit in a rain storm.
2. The speed limits for the curves like those on that track will be like 25 MPH. He must be going well over 50 MPH on those curves.
Would the better tire still be better at speeds under the test speed? Mmmm....???
I had the Nankang tire blow up parking in my driveway after being 3 months old. Stay away from Chinese tires if you don't want to total your car.New CTR owner in New Jersey. Of course taking delivery in the middle of the winter season creates the tire issue as has been discussed in numerous threads.
after reading everyone’s choices about going either wider, higher aspect ratio, or changing out wheels for 18” or 19s, I started doing some research.
Nothing on Tire Rack, but Discount Tires Direct has Nanking NS-25 AS in our stock sizes and they are very inexpensive.
Has anyone used these or are they just something to avoid?
Don't get me wrong. I know the value of a good set of tires after my scary experience with those terrible Nankangs.Speed aside, they're also terrible in wet braking too. Up to you though, it's your car.
To a great extent that's correct. In a serious storm snow clearance is the issue. With the CTR and a lot of other cars, you're not going anywhere if you have to plow your way through the snow cover. The issue with A/S vs. winter tires appears to be with cleared relatively dry or wet, not snow, conditions with temps in the 20s to 40s F, or less . That appears to be when the compound comes into play. Your choice as to what kind of handling performance you want in those conditions.I live around NYC/NJ area and have use A/S M+S tires (Bridgestone Potenza, Michelin Pilot Exalto) exclusively on my Prelude for 20 years thru moderate snow storms and light ice storms without problems. I think if your ride is FWD and live in a metro area in NYC or south of, then a good set of A/S M+S should be good enough. With a performance car, it's the low ground clearance that gets you stuck. The only time I got stuck in my Prelude was when I venture out during a snow storm on an incline with about 3 or 4 inches (or maybe more) of snow covering before the first plow truck had a chance to plow and lay down a coating of salt. Good thing I carry a compact shovel and was able to free the Lude back to safety.
When it comes to tires, you literally get what you pay for.New CTR owner in New Jersey. Of course taking delivery in the middle of the winter season creates the tire issue as has been discussed in numerous threads.
I've made this argument in the past, but found it to be false in reality.
- Many balk at the upfront cost of having Summer and Winter tires, however over the life of the tires, they are no more expensive than All-Season tires since they last around twice as long (each set is only used around 6 months of the year).
regardless the value of my car, i still care if it will ditch or not. Sometimes it just take that small accident to cause a life of our love one.I've made this argument in the past, but found it to be false in reality.
What that adds up to is 2 sets of tires that, combined, might get as many miles as 1 set of all-season but for the price of 2 sets of all-seasons.
- A good set of winter tires will cost about the same as a good set of all-season and have about half the tread life
- A good set of summer tires will cost more than a good set of all seasons and will last less than half the miles. Let's call it half for the sake of argument.
The value in season specific tires is the added safety/performance.
That said, I have all-season on my winter/beater car because I don't care if it ends up in a ditch and a set of winter tires cost more than I paid for the car.
I don't want to be disagreeable, however, I have lived the the "frozen" midwest for 60 of my 69 years of life and have never used winter tires. The one acceptation is the most recent A/S tires I purchased for the Rav also has the mountain snowflake on the sidewall so they are winter rated.When it comes to tires, you literally get what you pay for.
All Season Tires are not winter tires and should not be utilized in lieu of; All Season tires are meant for temperate climates where snow or ice does not occur.
Not saying that A/S is unsafe... million of ppl use A/S in deep winter with no problem.I don't want to be disagreeable, however, I have lived the the "frozen" midwest for 60 of my 69 years of life and have never used winter tires. The one acceptation is the most recent A/S tires I purchased for the Rav also has the mountain snowflake on the sidewall so they are winter rated.
Way back I remember my Dad buying studded snows when we moved from Texas to Chicago area out of fear and they lasted about one year. If it snows enough that I should have dedicated snows or chains on I stay home. Even with crappy snow removal around here we usually have the main roads/streets cleared within 24 hours. We live on a circle drive that has an approximate 30 foot rise in 20 yards to the main street and my Rav with A/S tires has never failed to get me to the main street...deep snow, packed snow or ice. Some will say: "but it's all wheel drive". Yes it is but it operates mostly in front wheel drive even in snowy conditions.
Even with the A/S I put on the CTR it is going to stay in the garage in bad winter conditions. That's why I have the Rav.
Having grown up in CT and lived in Philly for 30 years, I largely agree with this. When I first had my 2001 Saab 9-5 Aero, I bought a set of winter tires per the advice from Car & Driver and others, but found they really weren't necessary. In fact, I got through a massive Midwestern blizzard with some Sumitomo UHP A/S tires in 2005. Pickups and SUVS had spun off the road, and I just chugged through, feeling solid the entire way. I was astounded how well they did. Since then, both on the Saab and my 2010 TSX, I've never had any issues driving on Continental Extreme Contact AWS tires in occasional moderate snow, even though they don't get the best ratings for winter traction. If there's heavy snow I won't have to drive anywhere anyway, so no big deal.I live around NYC/NJ area and have use A/S M+S tires (Bridgestone Potenza, Michelin Pilot Exalto) exclusively on my Prelude for 20 years thru moderate snow storms and light ice storms without problems. I think if your ride is FWD and live in a metro area in NYC or south of, then a good set of A/S M+S should be good enough. With a performance car, it's the low ground clearance that gets you stuck. The only time I got stuck in my Prelude was when I venture out during a snow storm on an incline with about 3 or 4 inches (or maybe more) of snow covering before the first plow truck had a chance to plow and lay down a coating of salt. Good thing I carry a compact shovel and was able to free the Lude back to safety.
