Cold Start Rattle Noise
Andre80
white civic
Europe
Civic X 1.5 sport +
Al 99% è quella staffa, i dadi probabilmente non sono molto stretti, chi ha questo rumore, prova a toccare quella staffa con il dito mentre fa rumore
Honda Civic 10th gen Cold Start Rattle Noise staffa
CastorX
Balázs
Germany
Civic 1.5 Turbo Sport Plus
"At 99% it is that bracket, the dice are probably not very tight, who has this noise, try to touch that bracket with your finger while it makes noise" by Google translate. Not like it really needed a translation. Is that the actuator and the arm that controls the wastegate?
Andre80
white civic
Europe
Civic X 1.5 sport +
Yes, when it makes noise it is clearly seen that it vibrates
Rob2112
Robert
Richmond Kentucky
2020 Honda Civic Hatchback Sport 6MT
Mine makes the same noise to, I'm going to check it this morning to see if it is that bracket if so what is it that we need to do or if anything at all ??
I have about 2600 miles. 2020 Hatchback Sport MT.
CastorX
Balázs
Germany
Mine is quiet now. I heared it once or twice after the oil change. Then I tried to rotate that tiny metal stuff on picture with my finger. But it's not easy. Since then it's quiet. My theory is that the oil change (to 5w30) helped with other disturbing noises at startup, and ... I might have thightened the metal thingy with my finger but I'm really-really not sure.
Cainho
europe
fk8 type r
Rob2112
Robert
Richmond Kentucky
That doesn't sound like mine
Mine has more of a metallic rattle and could only be heard outside of the car.
Noticeable on cold start up in warmer weather mostly, doesn't do it at all in cold weather startups.
Your's may be something else.
Please post if you find out something otherwise.
CastorX
Balázs
Germany
No way! My 1.5 does the same noise. But yours is a type-r right? Sometimes i can hear the same noise as in this video. On one day quiet (i can barely hear it) on the next day louder. I think it also might depend on engine temp.
Rob2112
Robert
Richmond Kentucky
No way! My 1.5 does the same noise. But yours is a type-r right? Sometimes i can hear the same noise as in this video. On one day quiet in the next day louder. I think it also might depend on engine temp.
No I have the same type 1.5T 2020 hatchback.
Hard to tell from the video but didn't sound the same but I have not had any issues or taken it in, it may just be the linkage on the turbo charge.
Until it heats up and expands who knows I'm not gotten a definite answer but I've heard many have had the same sound.
I got over 13,000 miles on it as of now.
But I must admit I was concerned about it at first around 1200 miles is when I noticed.
