CEL + other lights after CAI Install
lilrobot
Kameron
Layton, UT
2019 Civic Si Sedan
I'm a little new to modding so bare with me!
Recently I installed the PRL Cobra Street CAI on my '19 Si and it's been treating me well! However, a couple days ago my CEL turned on and all the extra systems in the car shut off, like TCS, Power Steering, Brake Hold, Hill Start Assist and Emissions System.
I did some more research and found that I needed to reset my ECU after installing the part, so I did. Lights turned off, ran it through an idle learn and it was fine for about 70 miles until they all popped back on. I decided to clean the MAF Sensor and reset the lights again and found that the issue still popped after the same 70 mile mark. The engine code being thrown is P0171 - System too lean Bank 1
Below is pictures of my dashboard & the intake installed on my engine.
Honda Civic 10th gen CEL + other lights after CAI Install 20200108_133437
Honda Civic 10th gen CEL + other lights after CAI Install 20200103_150306
Honda Civic 10th gen CEL + other lights after CAI Install 20200103_150325
Any ideas? I've tried ECU reset, battery reset...I was told on PRL's site that the street version wouldn't require a tune so I'm a little lost on where to go from here. The tubes seem tight up top so I don't feel like it's a vacuum leak.
REBELXSi
Señor Member
Are you sure it's the street version?
lilrobot
lilrobot
Kameron
Layton, UT
2019 Civic Si Sedan
Try reconnecting the maf sensor
I did try that after cleaning it. Put me back to square one after 70 miles like in the OP.
I'm 99% sure it is, or at least should be -- my receipt from their site says I purchased the Street version. Is there a way for me to tell if it's Street vs Race on the actual parts?
lilrobot
lilrobot
Kameron
Layton, UT
2019 Civic Si Sedan
Right on the head -- I got sent a racing MAF housing and didn't even notice haha.
Honda Civic 10th gen CEL + other lights after CAI Install 20200108_213348
Here's hoping they'll let me swap this out for a Street one. Thanks guys!
REBELXSi
Señor Member
:cool:
Steelsi
Daniel
Santa Maria ca
2019 Honda Civic is
Np good luck I’m pretty sure they would sense I accidentally bought the non si version maf and then called them and they switch it out to the si maf
Driver56
RVA
2018 Civic SI coupe
Now I'm going to have to check mine when I get home, lol. What issues would I have running a non SI housing on my Si?
