My friend blew his motor on TSP stage 2
Status
Not open for further replies.
Lagos
Philadelphia, PA
2018 Civic Type-R
Cylinder 4 blew on his and driver B. That’s right next to tranny. My cylinder 3 blew And just missed it.
What was your motor replacement cost in the end? Did you replace it with a used motor or a new build?
amirza786
A
Northern California
No idea bro. I’m a musician and want to focus more on that. I want my first album to debut by the end of next year.
I want to buy the first one off the press!
Since its JDMpo0kie, you know his first album is bound to blow up... I mean, you know, be explosive... :nixon:
Sorry, I couldn't resist.
IcySerg
Sergio
Woodside California
2017 Civic Si Coupe
I’m curious, which version of tsp stage 2 was he on? I know Drob released a second revision of TSP stage 2 for those that purchased the first revision when it came out
JDMpo0kie
JDMpo0kie
2017 Honda Civic Si Coupe
I think the original version. But that is irrelevant when our injectors will fail on ethanol faster. I’m guessing he leaned out just as I had. I told him to get his old injectors and have them tested.
IcySerg
Sergio
Woodside California
2017 Civic Si Coupe
I see, just to put it out there, for those that don’t know. Revision 2 of TSP stage 2 significantly reduced the torque throughout the power band. Especially down low.
Keep us updated Pookie, how many miles did he have when it blew?
James3spearchucker
El Paso, Texas
Excellent. Thank you.
Too costly for my blood. I stick w Mobil European FS formulation 0w40, cheap and readily available and my little secret.
Anyone used this or heard of it. Read great things in testing.
https://www.amazon.com/Renewable-Lubricants-Bio-SynXtra-Performance-Gallon/dp/B00C3M34NS
You may want to try Motul's 0w40 XMax(made in France). It is their formulation with the most percentage of esters. I also like LiquiMoly Synthoil 0w40(made in Germany).
JDMpo0kie
JDMpo0kie
I forgot exactly how much. I know he had more than I did. I had 44k when it happened. I think he said somewhere around 55-60k
I asked this before in a different topic regarding the injector issue but would using a fuel additive like Gumout Regane have any benefit? They claim it cleans injector corrosion (from ethanol) in DI engines. I always use top tier gas as well.
Also, while I was adding a "most used fuel" stat to the tuning survey, I noticed a trend. Because 93 octane isn't available in California, quite a few guys from there are running ethanol blends. Maybe that and the potential injector issues that could occur is a major contributing factor to tune failures?
Status
