Design
- Sep 28, 2015
- 28
- 3,329
- 2,903
- Southern California
- 09 MS3, 17 ABM Si Sedan
We've seen air turbulence impact maf readings as well. It was a huge problem on the L3VDT TCDI motor, regardless of MAF housing diameter. A well designed intake system factors airflow at various rpms, often by leveraging some form of air straightener to help limit fuel trim spiking.Yes, you can look at the fuel trims with a $20 OBD2 to Bluetooth dongle and a free app like Torque on your phone.
No, it actually IS that simple. The distance, location and bends do not matter. You can have whatever design you want as long as the section that the MAF bolts on to has the same ID as the OE intake design. That's why PRL doesn't touch the MAF housing and just gives you a silicone pipe so that you can get the sound effects without any change to the flow rate equation.
Trust me on this. I'm an engineer for the automotive industry.
Here are some basic readings with/without the use of a straightener, all other parameters held constant.
