2019 Civic Si Coupe rear tire cupping!?
James96
Granbury, TX
2019 Civic Si Coupe
So i have a 2019 civic Si coupe, total of 8,000 miles. Installed D2 lowering springs about 5,000 miles ago. Over the past 2 weeks or so during my highway driving (60mph and up) noticed a terrible vibration felt in the seat and floor boards of the vehicle along some vibration in the steering wheel. Checking over the tires today i found the rear tires are wearing at an alarming fast rate, i expected some camber wear with the drop but I've got cupping on the inner edges pretty badly. I've attached pictures below (rear tires on the left). Is anyone else having this issue? I double checked all the suspension components and shocks, ect... all at proper toque and shocks not leaking. Front tires are wearing great, and as i ran the same springs on my previous 2017 civic ex hatchback for over 50,000 miles with little to no tire wear i didn't think an alignment was necessary with this one, could it be possible this is where i went wrong?? Any help would be greatly appreciated!
Honda Civic 10th gen 2019 Civic Si Coupe rear tire cupping!? front tires .JPG
Honda Civic 10th gen 2019 Civic Si Coupe rear tire cupping!? rear tires .JPG
Jeffers
Jeffers
Long Beach, CA
2020 Si Coupe purchased on 11-24-19
Had that problem with our Honda CRV , and everything is stock on that car. I know what you mean when you say terrible vibration brotha'!
The safest advice I can give you is get an alignment.
On the CRV I did a DIY alignment and got lucky!
Some guys lower the front to get faster handling with EVO's.
So you could put the stock springs back in the rear and see it you like the change in geometry.
ShadowFiend
SanaBanana
ONT Canada
2019 Civic Si
I'm actually at a dealer right now cause I can't bare the cupping noise and the fact that the car is pointing towards the right when the steering wheel is straight. Hopefully the mechanics here are good enough to notice
JT Si
Place
Car
Yeah....
It sounds like you didn't get an alignment or install camber arms with those springs. The extreme 1.9" drop puts your rear camber too far out of spec to just let it be.
Did you cut the bump stops when you installed the springs?
Design
Southern California
09 MS3, 17 ABM Si Sedan
If you can get your Toe alignment in spec, preferably from a shop that does racing alignments, you'll notice a huge improvement. But I can tell already that those tires are done.
Jeffers
Jeffers
Long Beach, CA
It's either too much toe-in [case with the rear of my CRV] or camber thrust caused by too much negative camber.
CanadiaegeanBlue
Humza
You have to get rear camber arms after lowering your car - K-Tuned, SPC, and some others make it. I have the K-tuned ones. Also, rotate your wheels and tires more frequently once lowered to distribute wear more evenly.
Also, get your car aligned and post a scan/picture here
Design
Southern California
My money is on a severe Toe misalignment. The third pic clearly shows feathered wear on the bottom two tires. And the top two aren't far behind.
Camber is also a factor here. But the heat buildup on the inner edge suggests the tire was being scrubbed pretty good. My hunch is that Toe is off by at least 1-2* in the rear.
James96
James96
Granbury, TX
2019 Civic Si Coupe
Thank you guys for the responses, I've got a new set of Truhart rear camber and toe arms ordered along with 2 new tires. once they get here I'll get some pictures of the before and after alignment specs.
RKS17
OH
G37s
I assume the Si has 0 adjustability with the OEM setup or simply not enough to handle a 1.9" drop (understandable)?
JT Si
Place
Car
The rear camber is not adjustable without upgrading to adjustable upper control arms.
The rear toe is adjustable, however I am unsure of the range. I assume the upgraded adjustable rear toe arms offer increased range.
RKS17
OH
G37s
Toe is a more important than camber. I'm NOT lowering the Si but are there quality springs that give a more conservative drop?
Neddih
Rochester, NY
2019 Civic Si Sedan
I think the eibach pro kit is more conservative
JT Si
Place
Car
The least drop I've seen is the whiteline lowering springs at 20mm. I don't like the change is spring rate bias they present so I'm looking at the Swift springs.
The Pro Kit is 0.9"(23mm)
mauiSI19
Jon
Maui
Honda Civic SI 2019
On eibach prokit. Once it settled the gap between fender and tire was finger width.
absolutely 0 issues.
