josby
- Dec 11, 2015
- 24
- 866
- 567
- Central VA
- 2016 Civic Touring sedan
- #46
I think it will. Another member here measured his EX's headunit, which is one that has the amplifier built into the headunit rather than external like mine, and he found the same results. So it seems all Civics sold in the US probably do this, and I can't imagine why they'd do differently in other markets if they have the same speakers.ti have a 1.5 T CIVIC HATCHBACK made in englend - SPORT model - do you think it will measure the same ?
what kind of equipment you used to measure it ?
The equipment I used is no longer made, but it's basically just an accurate soundcard. Soundcards have a much lower maximum voltage they can accept as input than the stereo sends to the speakers, but you can get around this by either creating a voltage divider circuit with some resistors, or creating pink noise test tracks that are at a very low volume level.
For just checking if the bass level changes relative to the rest at different headunit volume settings, you can also just use an accurate microphone with an RTA program to measure the speaker's output. That's what the guy who checked his EX's headunit did.
