Cobra CAI, P2187 Error Code
Landonlapore16
Landon
2018 Honda Civic Si
Hey guys,
I just installed my CAI Cobra on my 2018 civic si, running Ktuner TSP Stage 1. I am recieving an error code of p2187. This error code states that the car is running lean at idle, yet im at 14-15 AFR at idle, which from what I read is normal. I have also done W.O.T tests and am seeing an AFR of 11.5 -12.4, and finally at cruising speeds I'm seeing 14.5 - 15.4... I am not sure why this code is popping up. The car, from all the reading I've done according to ktuner software, is running correctly. Yet my cars system seems to think it's not and keeps popping up with "Emissions system problem" on the dash. I would appreciate any help, because I can't figure it out. Has anyone had this issue before? Could I be affected by the emissions system recall? There are no other lights on the dash, nor does ktuner read abnormal numbers on AFR.
Suggestions? This is really anoyying since I've heard nothing but great things about the Cobra.
Averia
Arco, ID
2018 Civic Si Sedan
Generally it is something in the intake path that is letting in more air than the MAF is registering. I had this code yesterday and it appeared to be caused by a loose connection to the intake manifold from my catch can. I cleared the code and tightened down the clamp. The hose was loose enough to easily pull off so the extra air was most likely being introduced there. So basically look for anything after the MAF that is loose, ripped etc. Make sure the hose to the turbo isn't ripped or not seated correctly as that is one you replaced with intake. That would be the most likely but as it was in my case the issue can be anywhere along the intake path.
laz's SI
Lazaro
Miami, Fl
2019 Civi SI 4 door/ 2017 F-150
Are you using the street of race Maf?
whoisJSR
Las Vegas, NV
www.avgntrials.com
2017 Honda Civic Si Coupe
Just got this code as well. Haven't figured out the cause yet. Did you happen to?
Edit: race MAF for me
Edit 2: stage 2 Flex fuel tune. My AFR hovers around 14.7 which seems high for E40... Might post logs if I need to.
ocbooger
Jason
Dyer, IN
2018 Honda Civic Sport Touring Hatchback
Hey guys,
What are your fuel trim readings? Are you sure your using the Si PRL intake and not non Si? Is the TSP stage 1 tune for Race, should say RACE in the file name they send you. Also did you switch your maf to race in Ktuner?
Joev492
Joe
New York
2019 Civic Si
I'm actually having the same issue, starting right after my catch can was installed. I have not tried adjusting the tubing clamps yet. I found my oil was filled much too high so I drained and refilled to an appropriate level. Here is a data log immediately proceeding the oil change...
Connecticut
2017 Civic Hatchback CVT
I know this is old but I have something similar happened while doing a WOT. Found out one of the clamp from the Intercooler bend was loose and had to retighten it. After tighten down the clamp, the code goes away. Hope this helps someone.
