How does it feel while driving? Any noticeable change?I just installed my Cusco front lower bar. Fitment is tight but it’s fine.
One thing of note that isn’t really mentioned anywhere is...you have to remove the stock lower air box. Odds are that if you are modding, then you have an intake and that box is useless weight already...there are 2 visible 10mm bolts and one “hidden” 10mm bolt that attaches to a black elbow type bracket. The bolt basically blocks the bar from being attached flat, so it needs to go...
the suspension bolt is 17mm and super long. You do NOT have to remove all under-carriage stuff but it does help a lot. What you can do(and what I did) is...take out certain black plastic clips to get more access and flexibility in the undercarriage area...
For a second I thought I was at a different site.Got around to installing this thing today. I love it.
Looks good but the Honda emblem is upside downReplaced the chrome front with the black front and replaced thr cracked foglight lens and put in two led fog lights. Good day today
Plug and play? How much?Got these LEDs today to replace those yellow-ish halogen low beams.
