Questions about raising idle
SouthSideBeef
Steven
Charlotte, NC
2023 GR86
Does anyone know why there's multiple targets in the idle tables? Just curious if I have to change all the targets or just the first one. Also can I adjust the idle on the TSP stage 1 tune? It doesn't seem so.
whoisJSR
Las Vegas, NV
www.avgntrials.com
2017 Honda Civic Si Coupe
Sorry to revive an old thread: so when you say "change them under normal", is this before I upload the tune? Or is this part of the tune itself? I have the TSP Stage 2 (flex fuel) tune, and I have an issue with my car; I need to raise my idle to 1050-1100 or so to see if my hunch is correct.
kytos
Marcos
Madrid - Spain
CIVIC SPORT 1.5t 2017 EUDM
whoisJSR
Las Vegas, NV
www.avgntrials.com
I mean... I appreciate you, but I already knew that lol. That's my fault, I wasn't specific enough :/ I specifically mean with the TSP (or any other tune that appears to have it locked). I have already reached out to @Two Step Performance in the hopes they can help. I really love my Stage 2 tune, but I'm having an issue that I cannot diagnose without raising my RPM, and I cannot rule out that the Flex Fuel mod is a source of the issue until I can do so.
(I don't even really need the option to raise it at will although that would be nice... Just having a new tune with the RPM target at idle being 950 to 1100 would be enough).
kytos
Marcos
Madrid - Spain
Sorry! I use to deal with less experienced users hehe Tho, you can use the base tune as an alternative to check. What is the problem if you don't mind?
whoisJSR
Las Vegas, NV
www.avgntrials.com
It's a long story, but it began with my exhaust and downpipe install. My engine immediately began smoking. I've been trying to diagnose the issue and I suspect that a lack of back pressure due to the larger exhaust (PRL Catted downpipe and a 3" AWE exhaust) + enough blow by (I do not have an oil catch can) is causing oil to burn in the turbo, and it smokes, but only after high boost and only after long drives.
The car runs fine in every other way. There are zero symptoms outside of the smoking. When I raise my idle 200-300 RPM the issue goes away (seconding my suspicion that my back pressure is causing it; I manually raise the idle by giving it more throttle and boom, the smoking stops!).
I've already got another thread to talk about this issue, but TL;DR I'd like to drive the car with higher idle for a few days to see if the car smokes at all. If it stops, then I think my suspicions are correct and I may try a PCV valve delete + catch can to see if that resolves my issue.
whoisJSR
Las Vegas, NV
www.avgntrials.com
(and since I added my Stage 2 tune at the same time, I'd like to keep the tune on during this process so I can rule it out. I did my flex fuel install and tune the same day as my exhaust install)
