Eibach 25mm Sway or AFE Front + Rear Sway?
fiachamp
FK8 CTR, DC5 RSX Type S
I purchased the Eibach 25mm myself then received the AFE Front + Rear kit from my parents for my birthday. Which should I actually install? I know StigJDM was running the Eibach rear sway last I saw, though he recently had a break at Buttonwillow. Which do you guys thinks gives the best turn-in + balance, from your track day experience?
ipeefreely
Will
Bay Area, California
2017 Ford Raptor / 2019 CTR
Never used AFE but I personally went with the Eibach.
What you want mainly is a little bit of adjust ability from the sway bars so I imagine you can't go wrong with either sway bar.
Turn in + balance on track can be dictated through many other mods.
Last but not least, I don't think the front sway is necessary. Car will handle like it's on rails with or without an aftermarket front sway bar. You should also do some research into what a pain in the ass it is install as it will heavily deter you from doing so.
