Is anyone familiar with the torque #'s required to re-tighten the bolt after installing the inserts?
If i use the CTR RMM on my Si will I need to order a new bolt?65ft-lbs for the 19mm bolt and 55ft-lbs for the 17mm bolt
The one for the Si is different than the Type R. Part number below.Will this fit a 2020 Si? I assume it would.
Yeah because the type r rmm is a tad differentThe one for the Si is different than the Type R. Part number below.
Si : PHP-DRV-100
Type R: PHP-DRV-101
