Effective mods without a tune
RicEeyEs
Annandale, VA
10th civic Si
whats cookin good lookins
As I am only 7k miles into my 60k warranty I don’t necessarily want to get a ktuner just yet. Well, obviously I do but I’m trying to play safe as long as I can. Just wondering what mods you’d recommend to give me some better performance or what you’d recommend anyway. So far I have a Perrin strut bar, whiteline rear sway bar/ end links, and a torque solution rmm. I know I should obviously get some grippy tires and probably lowering springs (I don’t necessarily want to shuck out a ton on Coilovers just yet)
RicEeyEs
Annandale, VA
10th civic Si
I should add that I am ordering a skunk2 shift knob and likely prl cai later this winter
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
Acuity shifter or upgrade parts, rmm, type r rear brace
SHAYN3R
SHAYNE
CAMBRIDGE
2018 Civic Si
I agree with lightweight wheels. I noticed a significant difference when I upgraded. My wheels are 18lbs/wheel opposed to the 29lb stockers.
jakabony
Jake
Pittsburgh PA
www.facebook.com
2017 Honda Civic Si, 2019 Honda CR-V EX-L, 2017 Subaru Forester
Upgraded rear sway bar and end links (Whiteline or Eibach RSB, Accord end links), Type R shifter with Acuity goodies.
RicEeyEs
Annandale, VA
10th civic Si
Go ahead and upgrade your clutch before you tune to get ahead of the game. CTR retrofit should be on every si wishlist.
Is the modification to the ctr clutch fairly simple? I was thinking about a lighter clutch a little down the road
RicEeyEs
Annandale, VA
10th civic Si
ALready have whiteline sway bar, it feels awesome hitting highway exit ramps. The whiteline endlinks were a pain in the ass for me to find the right fitting for, and even still after buckling everything up I know something went wrong so I’m gonna I’ve someone else look at em. Should’ve went with accords endlinks
RicEeyEs
Annandale, VA
10th civic Si
I’m definitely thinking about at least the shifter bushings but I may as well just get the whole setup which comes with everything correct?
Paprocjo
IL
2019 Honda Civic SI, 2016 Mazda CX-5
Do you happen to know the accord end links p/n? I want to make sure I get the right one.
RRsedan
FL
2018 civic si
Lighter wheels and upgrade the intercooler
Is an intercooler upgrade really necessary if you're mostly (80% of the time) using the Si for normal commuting (i.e. shifting @ ~3-3.5k rpm using only light throttle to accelerate) and 20% / rest of the time is spirited driving / WOT above 3k rpm?
repeet
Fort Mill, S.C.
jesus7feasts.fyi
'23 BRZ
I went to Torque Solutions to look for the rear motor mount that you mentioned, but couldn't find it. Could you post a link?
86salmon
Chucktown, SC
I did Type R shifter with base bushings, centering spring, and rocker. It feels very smooth and precise
I got this package minus the cable bushings. I'll be getting them later
CanadiaegeanBlue
Humza
Here's my performance category mod list, and I've highlighted Green as most effective, and Yellow as second most effective. Those that aren't highlighted are just simple add-ons or unrelated to you if you don't want a tune, and Red are potential warranty losing items:
Engine:
  • Hondata +9 (would've been Green if you weren't concerned about warranty)
  • Mishimoto Intake (would've been Green if you weren't concerned about warranty)
  • Mishimoto Intercooler Kit w/Piping
  • Mishimoto Catch Can
  • 27Won Engine Mount
  • 27won Catted Downpipe + Front Pipe (would've been Yellow if you weren't concerned about warranty)
  • Invidia R400 Catback Exhaust
Transmission:
  • Acuity Short Shifter
  • Acuity Cable Bushings
  • Acuity Pedal Spacer Bracket
  • Acuity Shift Boot Collar
  • Mishimoto Carbon Fiber Shift Knob
  • Awaiting Install: CTR Retrofit Clutch by Eman
Chassis + Suspension:
  • K-Tuned K1 Street Coilovers
  • K-Tuned Rear Camber Kit
  • Ultra Racing Strut Bar
  • Ultra Racing Trunk Brace
  • Type R Subframe Brace
  • Whiteline 22mm RSB set to softer setting
Wheels and Tires:
  • Konig Freeform 18x8.5 ET35
  • Continental ExtremeContact Sport 245/35ZR18
  • Muteki Steel Lug Nuts
Brakes:
  • Front - Brembo 4-Piston Calipers from Hyundai Genesis Coupe, mated to Nissan Rogue with 3rd row seat Rotors (320x26mm). Stoptech Sport 309.10010 Pads, Mercedes Benz AMG DOT4 Fluid, and Goodridge SS Lines
  • Rear - OE Rotors + Pads, Rear SS Lines
  • Awaiting Install - Stoptech Rear Rotors, Type R Rear Pads
