[SOLVED] Ktuner check engine
CivicPlease
Rowland Heights
Civic Sedan
my check engine light went on after flashing a base map tune 1 with improved throttle response 2? Anyway to get around that?
CivicPlease
CivicPlease
Rowland Heights
Civic Sedan
I tried to flash back to the base map tune but now the check engine is still on showing no error codes? What do I do?
Tanuktun
Tomball TX
2019 Civic Ex Hatchback
sounds like you didn't power on/off correctly, I've done this before. key off, wait, key on(don't start the car), click ok, wait, check engine light should go away after it scans for issues.
CivicPlease
CivicPlease
Rowland Heights
Civic Sedan
I will try that tonight thank you
CivicPlease
CivicPlease
Rowland Heights
Civic Sedan
You also scanned and gave no codes?
bnb0523
2019 Honda Civic Si
Just run the car a little bit and the light will go off eventually.
CivicPlease
CivicPlease
Rowland Heights
Civic Sedan
Bro you saved my life lol. Thank you so much no more check engine light :)
Tanuktun
Tomball TX
I've done it before. Customer support is always available during the day, just email them if you have problems or questions. Lord knows I bug the piss out of them sometimes
CivicPlease
CivicPlease
Rowland Heights
Civic Sedan
Hahaha I messaged them last night. I saw your message first and tried it and it worked lol. I panicked for a sec
Mojoe2211
Moises
Los Angeles County
2017 Civic Hatchback LX Mods: Ktuner Stage 2 tune, PRL Cold Air Intake
I know this is a kind of old post but thank you very much. You saved me a freakout.
calvin13386
Singapore
Honda Civic 1.5T
I having the check engine light issue after flashing. i tried reflashing again or reset ecu but the check engine light doesn't goes off.
Your method of "key off key on(don't start the car), click ok, wait, check engine light should go away after it scans for issues", do you reflash again and start the car after click ok and wait?
Because I tried to reflash, key off key on(didn't start car), click ok, wait, check engine light does not go away, start the car, check engine light still there.
Tanuktun
Tomball TX
click ok, key off, (i wait) key on but dont start, wait, light is on then flashes then goes away
kimtyson
Kim
York, Pa
2020 Blue Civic Si Coupe
Isn't there something about keeping your foot off the brake?
Garbanzo
Jacob
Timmins, Ontario
2016 Civic Ex
Hey, I’ve done this and the check engine light is still on, maybe it’s because I have a muffler delete?
