SCOPESYS
- Geoff
- Aug 27, 2018
- 68
- 2,505
- 1,550
- MD
- 2018 Honda Civic SI Coupe. . . . . . . .1987 Nissan Maxima Wagon. . . . . . . . . . .1987 Nissan Pulsar NX . . . . . . . . . . . . . . . . . .1987 Nissan Maxima Wagon (2nd Donor Wagon for parts)
Honda Hack will not be able to control the Instrument panel's hard coded microprocessor to do any changes to the operation of color scheme of the Instrument panel.Sure sure. That I know. The issue is that if someone wants the whole red theme, that can't be achieved without changing out the whole console. That screen theme is not accessible unless HondaHack gets a lot more capable.
Although, I am pretty sure the temp and fuel are LCD in behind those slits.
The temperature and fuel are actually mechanical meters using stepper motors ( very well done to match the LCD graphics !!)
They actually step to max to reference the needle position, and then come back to the correct position when you turn on the ignition.
What is interesting, is that Honda also make the LCD display of RPM do the same thing, even though it is just a video graphic and does not need to "Mechanically calibrate), so that everything matches, and give the impression that it is all one integrated display. ( also looks COOL when it starts up and does that !!)
