Erin Tyres
- Jeff
- Apr 27, 2019
- 1
- 62
- 29
- Vermont
- 2018 Civic EX-T
My Civic is easier to drive than most other manual transmission cars.
1) Brake hold means that the car will not roll backwards when starting on a hill.
2) An electronic interlock keeps the engine from starting unless you are depressing the clutch.
3) Another interlock makes it impossible to accidentally shift into reverse when the car is moving forward.
4) The gears shift smoothly. Six gears are more than you need, but that's OK.
5) The engine has great torque. In most circumstances, you can punch the throttle and speed up without downshifting. (I have the 1.5 liter sedan, not an SI.) It seems like the engine never knocks.
6) The clutch is hydraulic, and a little part called a "clutch delay valve" restricts the flow of fluid to slow down the rate at which the clutch engages. This helps to prevent stalling and shocks to the drive train. Some people (the ones who turn off Traction Control and strive to get the best 0-60 times) have actually removed the part to get a more abrupt engagement.
7) The clutch engagement point is really low. The 2000 Volkswagen Passat that I used to drive had a self adjusting clutch, and there was no engagement at all until the pedal was almost completely released. For a beginner, that can be hard to get used to. In the Civic, the clutch begins to engage and the car begins to move by the time the clutch pedal is just two or three inches off the floor.
8) There is a really good digital tachometer on the instrument panel to help you see what you are doing. The top of the speedometer has colored LED's that show green when you are driving in a fuel efficient way, white when you are not, and blinking red when the engine RPM is close to the redline.
Find someone with a manual transmission car and go for a ride. I think that you will like it.
