What could cause this..?
Zeffy94
Zeffy94
Matt
Doylestown, PA
Unfortunately, I predict that these issues will start to get even worse as the cars ages, and the fragile plastic parts start to get brittle from heat and UV sunlight.
Once they get old and Brittle, there will be no detaching & re-attaching without the plastic breaking, and needing repair with 2 part epoxy etc
Which is sad; I’ve also noticed the window trim is peeling off in some places and that was something I noticed in my last 10th gen as well.
Zeffy94
Zeffy94
Matt
Doylestown, PA
mine hasn't snapped back the same ever since i removed it the first time. I've been too lazy to remove it and try to make it fit better so it's gonna stay that way until i decide to remove it i guess.
Any of the clips broken?
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
not that i saw. the tabs on the bumper does look a little "stretched" though if you know what i mean.
If i push it in, it'll be flush but just pops back out so i might add some plastic weld to make the holes on the tabs slightly smaller and/or to try heating the plastic clips on the brackets under the headlight and the fender area with a heat gun and bend it up and see if it clips in better.
Thats when i have more free time to remove the bumper again and to mess with it.
Honda Civic 10th gen What could cause this..? 61RciKw
Zeffy94
Zeffy94
Matt
Doylestown, PA
What does behind your side marker look like? Mine is all jacked up.
Do you have a gap between the headlights and the bumper too?
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
mines clean. The side is easy to pop off so i popped it off the other day and none of the tabs were broken. Just looked "worn and stretched". I'm thinking thats why it's not clipping as good as it was before.
My gap between the headlight bumper isnt as bad as yours. I only really see the very outer clip under the headlights. If i push it in, a lot of the gaps on the fender area gets minimized also so i'm thinking i should try to do some adjustments to make it fit better in that area. I just didn't look too close cause in order to pop out that area i have to remove a lot more clips to pop it out.
Everywhere else is fine though. I suggest you fix those tabs with some plastic weld and then see how it is.
Zeffy94
Zeffy94
Matt
Doylestown, PA
That’s the plan, I just am worried about the overall longevity of some of these plastic pieces. Unless something did hit me and left no damage, but I have spent a good 10 minutes hyper analyzing the area for impact marks and found nothing.
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
plastic bumper clips are always an issue. Not just on this car but any car.
Doesn't help that honda used some very fragile clips. I've heard of people replacing the plastic bracket with the clips to fix the issues but i rather attempt the heat gun method first before i go and throw money at it.
i do want to plastic weld some of the tabs that look stretched and worn though. Better to do it now before it completely disintegrates like how yours is.
CW20038TypeR
Franklin
CW type r 2018
I didn’t see any fitment issues when they returned it after repair. Looking at older photos I took the gap doesn’t appear as large as it is now. I’m looking for any evidence of damage but I cannot see any.
For some reason in these pictures I feel the gap was there also but you didn’t notice it
Israel
Israel
California United States
My Bumper was repainted driver side was slightly hit. But I notice today my passenger front bumper looks like yours I agree with someone saying on this thread sometimes shops brake up things and put it back togethee tight pretending nothing happen here are somoe pics just like yours same side
Honda Civic 10th gen What could cause this..? 20191024_180243
Honda Civic 10th gen What could cause this..? 20191024_180236
Honda Civic 10th gen What could cause this..? 20191024_180239
CivilciviC
2018 Civic Type R
There's a reason I *never* skimp out on the cost of a high quality body shop. There's one shop in particular that I trust with any of my cars- it's also a one man operation and he isn't cheap. But the quality of his work is beyond top notch.
Body shops are like any business. Time is money. And if you got a great quote, they might be rushing things to get you that price. Maybe 9/10 times things go without a hitch. Until you come in and you're the 10th time.
If it bothers you that bad, I would look to another shop to have them fix the broken clips and reinstall the bumper. It might cost you... but what's your personal sanity worth? I bet that misaligned bumper is driving you crazy.
Israel
Israel
Yeah thats what I did when i took the Car in
Its my Insurance Bodyshop
But i might look for other one . It does drive me crazy Lol i dont any broken clips yet i try to open a little bit yesrerday the clips are fine till what i could of see yet
5th 3l3ment
5Th 3l3ment
South Carolina
19 Civic Si
Bought these on Friday due to my bumper on the driver side looking like ass this is for my 19 si sedan has had this issue since i bought it. Took it to Piedmont Honda here in Sc they sent me to their shop that claimed nothing was wrong with it alas a year later still having an issue so im going to replace the clips my damn self. If you want something done right gotta do it yourself ft dealership
Honda Civic 10th gen What could cause this..? 48EDE7BC-72A4-4DBA-AB7D-1563532A3BCC
Honda Civic 10th gen What could cause this..? 066C9C75-B7AE-4BA6-A7CF-5C0A9CEAD16A
Byron Sexton
DMV
2006 Mazdaspeed6, 2020 Civic Type R SGP #36784
Good advice here nothing to add. That is how bodyshops roll especially one's that handle Insurance claims. They rush and break some tabs then try to cover it up....
Archangel
Archangel
2017 Civic Type R CW #00006
I had the same issue with my former 17 Si. it was the right front you can see it by the turn signal.
mercifully my Type R doesnt have this issue........................yet..
Zeffy94
Zeffy94
Matt
Doylestown, PA
Well in my case it was already broken lol from the impact (7 mph...) body shop just didn’t repair it correctly I guess. I stopped caring about it because it’s hardly noticeable
