Deadgame
- May 20, 2018
- 16
- 90
- 31
- San Antonio, TX
- 2018 CW FK8
Hey guys, I purchased and setup the Autel BT dongle today and while I was making sure the tool could assist with my rear brake pad change, I started looking at what other info the unit could provide. I noticed that I might have a potential issue... What do you make of these failed results and is the number of misfires normal for these time spans/drive cycles. Lastly, what are "normal" parameters for AFR at idle, cruising and WOT? For reference, I have the PRL High flow intake, catless DP, FP and IC paired with an OTS Hondata map. Car has no DTCs and seems to run fine. Thanks in advance.
