Mod your ACT Sensor And Gain HP?!
idragmazda
CT
Fk8
Following. This seems like it could help those that have "heat soak" issues with IAT from driving in start / stop traffic. Based on how I'm interpreting this, it looks like the air is not necessarily as hot as the sensor is saying it is which is pulling power down.
I don't really care about more HP, i'm more interested in making consistent HP after driving through city traffic everyday.
@PRL Motorsports and @D-RobIMW any thoughts?
FK8_K20c1
HONDA The Power of Earth Dreams Technology!
Jonathan
Indiana
FK8 Type R
same here my friend
ExVTEC
Elliot
2019 CTR
I had a similar issue in my old Veloster turbo. I used a metal spacer to add a vacuum port and the car never felt the same. Later on using an app I can see the air temps were too high. I removed the metal spacer and the temps dropped but no more boost gauge.
PERRIN_Jeff
PERRIN_Jeff
Hillsboro, Oregon
2017 Civic Si Coupe
The first picture show with "SIDE SHOT OF SHROUD" is really the best one. It shows the part that needs to be removed.
Here is another picture. The part removed is the center piece, and it is only done to allow the sensor to be bent toward the middle of the opening.
You can even see some of the glistening oil touching the sensor and the housing.
Honda Civic 10th gen Mod your ACT Sensor And Gain HP?! actsensor1
PERRIN_Jeff
PERRIN_Jeff
Hillsboro, Oregon
2017 Civic Si Coupe
So in theory, the incoming air is passing over the piece of plastic that is holding the heat from the engine, manifold, etc..???
The only potential problem I can see with this is that shroud was in place to protect debris from incoming air.
But this is very intriguing, I'd be interested in seeing more data logs and dyno sheets from other users doing this.
You are correct! The air is passing over the small bulb (the actual air temp sensor portion) and the plastic housing of the TMAP sensor. The manifold and plastic housing heat up to whatever the charge temps are and hold that temp for a long period of time. Since the sensor is touching this plastic it is transfering the heat to the sensor.
Yes, the only potential issue I saw was it is less protected from debris that is entering the engine, but there are two things for that.
1. The shrouding left behind still protects it very well.
2. If you have debris in your motor that could damage the sensor, you might have bigger issues than a bad TMAP sensor HAHA
I just did this little mod. I did notice lower IAT temps but it was sporadic. It produces lower temps but it bounces around between 3-5 degrees plus/ minus. The temperature was lower though then the consistent high temps before the mod. Car did feel stronger. The temps drop fast when moving even at partial throttle. I usually only get this rapid temperature drop going WOT. From before and after was approximately 20 degree lower temp difference. I have to drive it around more to get a better sense on it. P.S When removing the part to do the mod. I noticed the temperature prob was drenched in oil.
That is interesting. I am seeing very smooth ACT readings after doing this. Meaning, My logs (as well as the dashboard) show a rather smooth increase or decrease in temps. Example, 2 degree fluctuation over a 5 second window. Nothing like a plus or minus 5 degree swing over 5 seconds.
But for 100% there was oil on the sensor. This is normal, and also doesn't help with the heat transfer. Maybe your sensor is not far enough away from the housing and oil is creating a point of contact?
PERRIN_Jeff
PERRIN_Jeff
Hillsboro, Oregon
2017 Civic Si Coupe
I want to make sure that everyone knows there are two IAT readings. Just to make sure you are looking at the IAT reading in Ktuner? In the Ktuner software, the have the charge temp sensor displayed as IAT, but I am not sure what Hondata uses. To me, the charge temp sensor should be labeled differently to ensure people don't think its the air temp sensor that is in the MAF/intake system. I mention this because If you have heat soak issues, I would make sure you are not looking at the wrong IAT reading. Secondly, if you have an aftermarket intake you could be seeing heat soak issues because of how the intake was designed. I have even seen heat soak issues and high intake air temp readings on the stock intake under extreme conditions (even on the dyno). As once that air box heats up, it makes for high readings during stop and go traffic and even under track conditions.
And you are correct, it is not that the air temp it self is causing a loss in power, it is the ECU pulling back the power because of the air temps. Two solutions: Find the other air temp related table (Ktuner has one of them exposed that limits boost based on air temp) in the ECU and modify it, or make for more accurate air temp readings. In the land of Subaru's, these tables are exposed and modified easily. This helps with making consistent power in a broader range of conditions without an unnecessary reduction in power. An example is, a dyno run with the intake air temp (at the MAF sensor) reading 110F versus 70F doesn't change the actual power at the wheels.
PwrOfDreams
It ain't a Type R then it ain't a tight car
None
Other
That would probably be the case. I didn’t clean the oil off because I didn’t have electronic cleaner available. I’ll clean it up later. I didn’t want to bend it out too much in fear of breaking the probe. I’ll revise it and clean it up better. So far so good since I daily drive this car in traffic and such.
PERRIN_Jeff
PERRIN_Jeff
Hillsboro, Oregon
2017 Civic Si Coupe
And it does take a bit of bending, to the point it may seem scary. Use a small flat head screwdriver and bend it from the middle of the probe, versus bending it from the "bulb" portion.
fk8mike
canada
civic type r
i will do mine today,so how about a already tuned car? it mean that whp will be more "present"?
FK8_K20c1
Jonathan
Indiana
FK8 Type R
Hondata uses the same name reference as Ktuner IAT1 and IAT2
tylermmorton
Tyler
Atlanta, GA
Civic Type R #1362
If the sensor is drenched in hot blow-by oil as some have noted, would it even accurately read the temperature of the air?
PERRIN_Jeff
PERRIN_Jeff
Hillsboro, Oregon
2017 Civic Si Coupe
I suspected that would be the case. I think that heat soaking while sitting at a light is still going to occur as air flowing into the manifold is very small and the sensor isn't seeing much air passing by it. But what I see is that once moving a little (or RPM's are above 2000), the air temp reading will drop faster to the actual air temp, vs hovering at a much higher temp for a longer period of time. I can't wait to see what other people see as well to help prove this to be a good mod for everyone.
PERRIN_Jeff
PERRIN_Jeff
Hillsboro, Oregon
2017 Civic Si Coupe
The hot oil would affect the reading for sure. I think that this mod will still make it more accurate as oil will not be "pooled up" around the sensor all the time, and touching the hot plastic. If it is out in the air flow more, it will not have as much oil constantly on it. In turn a more accurate Charge temp reading. Is this representing the exact actual air temp? No, but it is closer that it was before.
Hondanickx
Belgium
Cool mod ! Maybe you could insulate the sensor from the manifold and the surrounding area to keep heat soak to a minimum without modifying the sensor.
