This is true I used work a mile and a half from my house in New York my weekly mileage was 15 miles I used to try to put a hundred miles on the car over the weekend but after four years of doing this commute I’ve gone through two batteries two oxygen sensors this was my 2004 tiburon GTThat's exactly it. Two miles barely gets the oil flowing properly. And the engine clearly won't get to normal operating temps. Even the battery takes a hit because it's never getting much of a charge. A 2 mile trip is about the worse thing you can constantly do to a car (other than constant 1 mile trips lol).
I wouldn't. I like to ride my bicycle. There's so much you could do with the money with everything involved with buying a car (maintenance, insurance, accessories, fuel)I've been saving up for an Si for a while. But a new job may mean I have to take a train to work. The train station is less than 2 miles from my house. The engine will barely warm up by the time I'm there.
Would you buy a Civic with the oil/gas dilution issue if your daily drive was that short?
I agree walking can not only be good for your body but prepare you for a better day at work. I know what two miles can be like so I often jump on a bus for something that distance or hop on my bicycle. If you need to wear one clothes for work and one for the bike, that's simple as a backpack with the clothes. I have enjoyed faster warm-up in older cars that use port-injection, but the more power the engine makes, the longer it takes to warm up all that metal, expand the pistons to full dimension, and warm up all that water.I'd walk to work if possible. If not possible, you could get a hybrid and fill up every 6 months
My 2020 SI doesn’t have oil issues. But I wouldn’t by a car for a two mile commute, I would walk, much healthier. At least in the non winter months. Two miles should warm up fully if you get into the throttle some and it’s not all downhill.I've been saving up for an Si for a while. But a new job may mean I have to take a train to work. The train station is less than 2 miles from my house. The engine will barely warm up by the time I'm there.
Let's talk about what you just wrote. So --- as our cars warm up you need to take it easy on throttle. Ideally, you don't want to "get into the throttle" at that point.Two miles should warm up fully if you get into the throttle some and it’s not all downhill.
