Can't put some purposeful miles on it just to do a proper break in and get the factory fill out?My Civic is approaching 1 year.
It only has 990 miles on it.
Is there a limit where the break in oil needs to be replaced at 12 months?
Is there any other service due at 12 months of ownership?
You are supposed to change the oil at least once a year.My Civic is approaching 1 year.
I agree completely. You'll just have to use your best judgement. This is where a slightly more aggressive run in works well.The car normally gets used for 50 to 200 mile trips. I just don't make many. Probably one a month.
My old Cheyenne pickup has been much easier on my back for short trips.
I'm just not sure that 1,000 miles is enough for the break in oil.
I will watch them change it and check it too. Should look like light honey.One other thing.
If you have very low mileage when you bring the car in for an oil change, check how clean the oil is before and immediately after the oil change (before you even start it up). It is not unheard of for the mechanics to look at the odometer and decide that the oil doesn't need to be changed because it doesn't have many miles on it. Yet, they tell you that they did change the oil and charge you for it. The oil should be dark before the oil change (even with only 1,000 miles) and golden clear after.
