What’s latest firmware/ head unit update- also how do we check what our patch is?
Zatannaz
Robby
Virginia
Civic Touring Rallye Red
Just want to see if I have latest one and not sure where to see what mine is. Thanks!!
messenio
Tevin
Atlanta, GA
2017 Civic Hatchback Sport Touring
I'm pretty sure the lastest is 1.F197.00. Here's a thread that talks more about it, including a post where a forum member uploads the update file, but be warned it's only officially supported for hatchback models, and you cannot downgrade if you were to use it: https://www.civicx.com/threads/infotainment-software-update.16505/
yhkwok
Jonathan
Farmington Utah, Columbus Ohio
00 Galant ES 2.4, 18 Sienna XLE (FWD), 18 FK7 ST
Close, but I think my 2018 Hatchback comes with the newer one, can't recall the full name of it, but something like 1.F1A...
My recent service at the dealer did a check for that, they said they have just received a new USB (with the latest firmware on) within a month and it says mine's already the latest possible
CivicBuff
St Louis MO USA
2018 Civic Sedan EXT/HS, 2000 Honda Accord Coupe
FYI My 2018 EX-T/HS sedan built June 2018 in Japan has kernel 3.1.10+wed mar 14 2018 and build number 1.F1A2.34
BTW there are other threads on this topic ,, check out audio/nav/electronics
rohnin
Iris
Honda Civic Type R
Does the dealer automatically update when you bring the car in for service?
yhkwok
Jonathan
I don't think they do it as a routine, but if you ask about it, and if they're chill enough (like my dealer), they can check it for free, and charge whatever fee if they see it's update-able
integra15
Ann Arbor
2017 Civic SI
You dont want to go upgrading firmware from the hatchback to the coupe or sedan. Nobody knows what was changed and the acoustics tuning are completely different for each model. You do something like this it might be the newest but might make your sound worse overall.
Zatannaz
Zatannaz
Robby
Virginia
Thank everyone. This is all good to know.
steiven
Malaysia
Honda Civic 1.5 TC
My 2016 civic HU model MY16ADA using android 4.2.2 build number 1.F187.14 Kernel version 3.1.10+ jenkins@NDYWY3861584#1. Any latest firmware for this?
Merlanit0
Antonio
Miami, Fl
Honda Civic Si Coupe
Is there an update for the infotainment system? If there is, how could we install it?
das borgen
Richard
Columbus, Ohio
E36 M3, Ducati 748, '17 EGP Si Coupe
Is it possible to install the software from a Touring on a Si to get navigation?
