If your Civic SI is a lease and want good sound w/o upgrading sound system
WhiteSi
Georgia
2019 Civic Si
I made it all the way to "This car is rockin" with one more change:
Using Bluetooth Audio from iPhone with iPhone EQ set to "Loudness" mode!
I had the rearview mirror shaking from the bass! For me, that's the gold standard.
I am done modifying the audio with all speakers and sub remaining stock.
Thanks to the iPhone's built in AGC (I believe enabled via iTunes, I know, I am old to be still using that.) each track is coming out at the same level, despite a mix of 70's, 80's, 90's and 2000's music.
The pre-amp section in Apple products has always been above average, from back in the iPod days.
I did have to adjust the EQ a bit more and lower ViperBass to not blow myself away completely.
Remember, when I bought this car the audio was "Utter crap!".
aighead
Dayton, OH
snortcoffee.com
2017 Civic Si, 1988 Ford f250, 2004 Honda vtx1300
Though it's messing with some stuff I don't quite understand I may have to look further into these solutions. Thanks for the info gang!
saiko21
Sai
Sacramento
OK, I took some shots of my configuration. First off, in order to get any of it to work I first had to do this "Lock Effect Mode" Headset.
Even so, it is only working for USB music, and not Apple CarPlay. If anyone has that trick, let me know.
Here go the settings, starting with Spectrum Extension:
FirEqualizer: My trick here is to reduce low bass frequencies, focusing on the mids and highs as I like it. I use ViperBass later to bring in the low freqs, with an emphasis on the high end of low, thanks to this EQ pattern:
Field Surround effect:
Dynamic System is another bass booster, not sure why it is separate from ViperBass, but I split the effect between both:
Now, the centerpiece, ViperBass!:
And ViperClarity, for the high end!:
And that's the first time I've seen anyone post their Viper settings!
Again, if anyone knows how to make Viper apply to CarPlay, I would love to have that.
I will try with these setting today. My settings are little different but I enabled viperclarity and differential sound for HAAS effect
aighead
Dayton, OH
snortcoffee.com
Does all this junk work with just the radio also? I'm assuming by Bluetooth Audio you guys mean my normal Music app on my phone, right?
WhiteSi
Georgia
2019 Civic Si
Not sure why, but only works for USB, Bluetooth, and someone said Android Auto, which I cannot verify.
FM and Sirius will continue to sound like AM radio or NPR.
MavicTB
Terry
Dallas
18 Civic Si Sedan Aegean Blue
For android auto what settings do i mess with?
Is iy headset, speakers bluetooth?
I can confirm it does work for android auto. I only changed settings on the HU via viper4android following the settings posted earlier in this thread. When you hit the system power on/off in viper you can REALLLLLY notice the difference. I find the sub to be too high in "volume" at lower volume levels but at medium to high volume its perfect.
PandaXpress
EX-T with Honda Sensing
yes thank you i did not turn it on for the app, it sounds so much better
Jolavemma
Jacob
Northern va
2017 Civic Si
Can someone walk me through step by step how to download this . I try to download it from my headunit using browser but it tells me this file (vipers4android ) cannot be opened . What do I need to do to download this onto my headunit ?
CbusHondaFan
New Albany, OH
2006 Si TW, 2019 Civic Type R CW
Well count me as a V4A convert now! I just installed it this evening on my '19 CTR and it already has made a big difference in the sound quality and I haven't even fully configured all of the settings yet. I am so happy with the results so far and I'll try the settings WhiteSi posted in this thread. I also found a site that explains what most of the settings in V4A : http://vipersaudio.com/blog/?page_id=43
There's so many different settings that it's gonna take a bit of time to fully fine tune my audio but it's made a VERY noticeable difference already. I finally have bass! YAY!
CbusHondaFan
New Albany, OH
Well count me as a V4A convert now! I just installed it this evening on my '19 CTR and it already has made a big difference in the sound quality and I haven't even fully configured all of the settings yet. I am so happy with the results so far. I'll also try the settings WhiteSi posted in this thread too to see what effect they have. I also found a site that explains most of the settings in V4A : http://vipersaudio.com/blog/?page_id=43
Jolavemma
Jacob
Northern va
2017 Civic Si
Anyone know what settings should be on Viper4android on HU to FEEL the base instead of hearing it boom boom..? Lol
